Thread: 86 250R Front Axle
    Dec 2009
    Mountain Home, Id
    25
    86 250R Front Axle
    I was going to change the bearings out on the front hub, but the axle will not come out. The spacer on the rotor side of the hub seems to be the culprit. Right now I have it soaking in PB Blaster, and will do that for a few days. I assume that there are a few methods out there that have been used to get it off...which do you think would be best?
    -Soak with PB Blaster or diesel and try to beat it out
    -Take it to a machine shop have them press it out
    -Soak, heat, ...repeat
    Thanks!
    1986 ATC 250R
    1999 XR 400R
    2002 Yamaha TTR-225 - FOR SALE
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    Dec 2009
    Mountain Home, Id
    25
    Oh...sorry forgot to mention that I loosened the axle all the way, took the block off, and pulled the whole hub and axle assembly out. Now just trying to separate the axle from the hub.
    1986 ATC 250R
    1999 XR 400R
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    Wow never heard of the front axle sticking. If you are going to replace the bearings and seals anyways heat might be your best friend. Other than that pb blaster is the best I've ever use as far as penetrating oil.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    Dec 2002
    Orange County, NY
    1,772
    +1 on the heat. A regular propane torch is often not enough though. The cans that look just like the propane ones but yellow are MAP gas and they will get the steel to cherry red pretty quickly. You're not supposed to use a regular propane nozzle with them and I never would but I've heard that they work.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC125M
    Dec 2009
    Mountain Home, Id
    25
    Well I finally got the axle out...but I would up having to cut it out. Everything was so rusted together that even a press wouldn't budge it. But since I had to cut it, I had to cut through the inner collar that goes on the axle. I need one now and of course they are no longer made. If anyone has an inner collar that they would be willing to let go of I would really really appreciate it...of course I will pay for it too! This is the part that I need:
    Thanks guys!
    1986 ATC 250R
    1999 XR 400R
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
