A new MOOSE steel shifter has been order, it will need to be cut and extended.
I've also bought some FLUIDYNE aluminum radiators, which are around 20% bigger, we'll se how those need to be modded. I think the trike has a better water routing than the bikes, obligating the water to flow to one radiator first and then thru the other before going into the engine. The bikes have 2 "Y's" that, IMO, is not as good. We'll see.
Also I got from EBAY a 2008 kick starter that, hopefully, will clear the frame without any mods, hopefully. If not that's an easy fix. What I'm needing now is to get a silencer to connect to the titanuim header. I think the 2006 CRF250 silencer will fit best, but that will need to wait until some funds become available. I still have a some welding to do as well as fabricate the front and top engine mounts from aluminum, which hopefully, I'll try and make this weekend or the next.
Welding is going on this weekend. I'm really pumped with this project!!!
I'll keep you guys posted.
TORKER.
THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
