Results 1 to 15 of 30
Thread: 200s still wont stop leaking?!? Im pulling my hair out!
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    I got all the rust out of the tank and put a filter on it, nothing is getting past the filter its doing a great job, but the stupid carb still leaks gas and the wont shut off, its clean nothing in there, needle seems to be working good, but the leak persists no matter what i do, and if i block off the overflow then it just backs up into the carb and floods it out or runs out where the carb goes into the airbox boot.....
    Please someone help me, it did it with the old OEM carb and still doing it with the brand new chinese knockoff that i bought for it.... I really want to fix so i can ride, im desperate!! AND baffled i know there can only be a number of factors contributing to it but i have gone over them allready....
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Does it only do it when it's sitting or all the time?
    TF 07,08,09,10,11,12,13,14!
    Feb 2009
    303
    It does it any time that the petcock is turned on, stops after the petcock gets turned off and the float bowl drains, but when you turn it back on it leaks out the bottom again....
    Tusk Hand Guards
    TAG handlebars
    runaway is offline At The Back Of The Pack Arm chair racerFirst time rider
    bay city mi.
    154
    hello
    did you try adjusting the float until it stops leaking,i mean extreme bends to see if it will even seat the needle all the way? just throwing ideas at you. with the carb off the bike take the bowl off and hook the carb to the gas line and see if you can push the float up and seat the needle.
    1,736
    is the needle and seat valve warn out (the little rubber seat for the needle) causeing a bad seal therefore leaking? ALSO i have had this happen now that i think of it, take your float out and make sure its still floating properly, i had a 1987 yamaha warrior where the float stopped floating and i took a newer one out of a 1999 warrior. but if u said it happens on 2 carbs (OEM and chinese) then idk. GOOD LUCK i know the feeling. took us months to be as desperate to checking to see if the float floated, lol and yeah, check every dumb thing you can never be to sure.
    Feb 2009
    303
    yeah i bent it and its stopping the needle right where it should be at, and it still leaks, but its not worn since its a new carb too......
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    I just dont understand what would make both carbs leak the same....?
    Tusk Hand Guards
    TAG handlebars
    Mar 2003
    3,092
    Something isn't right...those knockoff carbs like what you bought are junk IMHO...
    Feb 2009
    303
    Yeah there junk in my opinion too, but the oem one was doing the same thing....?
    Tusk Hand Guards
    TAG handlebars
    1,736
    Quote Originally Posted by Russell 350X View Post
    yeah, i would vote on repairing your OEM, but i dont know the condition so
    Mar 2003
    3,092
    Did you rebuild the OEM carb? Kits are 15$ or so.....
    Feb 2009
    Rome,NY
    1,046
    Have you tried taking the bowl off and holding the float up?
    Feb 2009
    303
    Yeah and the needle closed at the exact perfect spot, after i adjusted it and it still leaks..... Took the chinese one off and put the OEM one back on and no more leaks, but the idle wont stop hanging no matter how i adjust it, im so frustrated!!!!!
    Tusk Hand Guards
    TAG handlebars
    Apr 2007
    UP of MI
    804
    Did you put a new float needle in your OEM carb?
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Feb 2009
    303
    No i looked and they were like $30 thats why i bought the junker Chinese piece of crap
    Tusk Hand Guards
    TAG handlebars
