Results 1 to 15 of 16
Thread: 87 tecate b1 brand new setup estimate.
    oregon
    668
    this is a little check up.
    i plan building this specific model from scratch if i ever make enough money.
    i went to this website calles powersportspro.com and looked up 1987 b2 tecate and didnt even make it through half the parts
    i was trying to add every little screw or anything that the bike had when fresh from the factory.
    i got through less than half of what i needed to build the bike up from piece to piece and heres the cart.
    i got to a little over 6 thousand dollars. but i only got a quarter into it so it my estimate would be well over 17000$ to buy every part for this bike and build it screw by screw.
    i may sound like a idiot to do this but these bikes are vanashing my point is there going to be like the tiger collection or any other rare bike never seen.
    Special Accessories
    Dillon Brothers Shirts
    FOX
    Helmet Cameras
    Buy OEM Parts
    Honda
    Kawasaki
    Suzuki
    Yamaha
    Oem Honda Parts
    Oem Kawasaki Parts
    Oem Suzuki Parts
    Oem Yamaha Parts
    OEM Accessories
    Aftermarket Accessories
    Aftermarket Apparel & Gear
    Honda OEM
    Kawasaki OEM
    Suzuki OEM
    Yamaha OEM
    _________________
    Cruiser Accessories
    Sport Accessories
    Harley Accessories
    Off-Road Accessories
    ATV Accessories
    UTV Accessories
    Tool & Supplies
    _________________
    Street Apparel
    Cruiser Apparel
    Off-Road Apparel
    Youth Apparel
    Street Helmets
    Youth Helmets
    Off-Road Helmets
    _________________
    Site Links
    New Vehicles
    Pre-Owned Vehicles
    Financing
    Company Info
    About Us
    Maps / Hours
    Dillon Brothers MotorSports
    Contact Us
    Events
    Photo Gallery
    eNewsletter Signup
    Check Order Status
    Customer Service
    Popular Links
    Shipping Rates
    Motorcycle Accessories
    ATV and Utility Accessories
    Honda Motorcycle and ATV Parts
    Kawasaki Motorcycle and ATV Parts
    Suzuki Motorcycle and ATV parts
    Yamaha Motorcycle and ATV parts
    Checkout
    View Cart
    Return Home
    Your Shopping Cart
    SKU Item Price Qty Ext
    11011-1208 CASE-AIR FILTER $60.17 1 $60.17
    11012-1308 CAP,DRAIN $6.23 1 $6.23
    11013-1136 ELEMENT-AIR FILTER $26.50 1 $26.50
    13091-1403 HOLDER,ELEMENT $11.21 1 $11.21
    13091-1404 HOLDER $23.31 1 $23.31
    13091-1405 HOLDER $14.91 1 $14.91
    14024-1140 COVER,AIR FILTER CASE $20.40 1 $20.40
    14073-1237 DUCT,AIR FILTER $43.52 1 $43.52
    92150-1506 BOLT $2.82 4 $11.28
    92172-0401 SCREW,6X14 (92009-1287) $2.33 12 $27.96
    92015-1259 NUT,FLANGED,5MM $2.45 4 $9.80
    92016-062 NUT,AIR CLEANER CAP $2.71 1 $2.71
    92171-1563 CLAMP (92037-171) $6.53 2 $13.06
    43001-1203 LEVER-BRAKE,PEDAL $59.71 1 $59.71
    92001-1034 BOLT,HEX HEAD,6X10 $5.77 1 $5.77
    92043-1013 PIN $5.54 1 $5.54
    92081-1640 SPRING,BRAKE RETURN $6.23 1 $6.23
    410AA0800 WASHER PLAIN 8MM (410B0800) $0.99 1 $0.99
    550AA2015 PIN COTTER 2.0X15 (550D2015) $0.99 1 $0.99
    54005-1135 CABLE-BRAKE $42.30 1 $42.30
    54011-1253 CABLE-CLUTCH $22.06 1 $22.06
    54012-1290 CABLE-THROTTLE $19.22 1 $19.22
    92037-1275 CLAMP $5.46 1 $5.46
    15001-1207 CARBURETOR-ASSY $290.44 1 $290.44
    92037-1313 CLAMP,CARBURETOR HOLD $7.80 1 $7.80
    132BA0620 BOLT-FLANGED-SMALL (132G0620) $1.45 10 $14.50
    16065-1124 HOLDER-CARBURETOR $43.02 1 $43.02
    92037-147 CLAMP,CHAIN OILER $4.05 4 $16.20
    92059-3731 TUBE,5.8X10.8X230 (92059-1431) $5.12 1 $5.12
    26001-1824 HARNESS,MAIN $19.68 1 $19.68
    92171-0652 CLAMP,WIRING HARNESS (92037-1069) $2.82 1 $2.82
    13081-1222 CLUTCH-ASSY $400.66 1 $400.66
    92002-1357 BOLT $2.62 2 $5.24
    92022-304 WASHER,PLAIN $2.33 8 $18.64
    13102-1078 RELEASE-COMP-CLUTCH $35.76 1 $35.76
    13116-1120 ROD-PUSH $15.49 1 $15.49
    600A1200 BALL STEEL 3/8' $1.04 1 $1.04
    92022-168 WASHER-CLUTCH THRUST $5.32 1 $5.32
    92028-1076 BUSHING,CLUTCH $22.74 1 $22.74
    92046-1049 BEARING-NEEDLE,WR25/2 $20.96 1 $20.96
    92022-1648 WASHER $3.99 1 $3.99
    92016-028 NUT 20MM $5.54 1 $5.54
    13116-1010 ROD-PUSH,CLUTCH $18.34 1 $18.34
    92065-058 GASKET CHECK VALVE $2.33 1 $2.33
    13206-1052 GUIDE-KICK $6.18 1 $6.18
    13234-1061 SHAFT-COMP,GOVERNOR $64.65 1 $64.65
    14001-5206 SET-CRANKCASE $478.14 1 $478.14
    14069-003 BREATHER $5.54 1 $5.54
    21083-1058 ARM $38.61 1 $38.61
    32085-1016 STOPPER,KICKSTARTER $5.28 1 $5.28
    42036-1177 SLEEVE $12.58 1 $12.58
    49046-1055 ROD-GOVERNOR $20.91 1 $20.91
    49111-1051 HOLDER-GOVERNOR WEIGH $33.48 1 $33.48
    92001-1829 BOLT,W/WASHER,6X14 $2.45 4 $9.80
    92150-1467 BOLT,8X15 (92002-1601) $4.56 1 $4.56
    92004-1063 STUD,10X35 $4.48 2 $8.96
    92004-1065 STUD,10X45 $5.26 2 $10.52
    92022-1634 WASHER,8.3X28X1.6 $2.76 1 $2.76
    92026-1238 SPACER,15X28X1 $4.96 2 $9.92
    92027-1838 COLLAR $14.68 1 $14.68
    92027-1839 COLLAR,15.2X17X4 $6.60 1 $6.60
    92045-1058 BEARING-BALL,6905Z $21.12 1 $21.12
    92028-1133 BUSHING,CRANKCASE $9.68 2 $19.36
    92028-131 BUSHING $21.41 1 $21.41
    92028-132 BUSHING $21.41 1 $21.41
    92028-1366 BUSHING $16.90 2 $33.80
    92037-010 CLAMP FUEL PIPE $2.45 1 $2.45
    92037-1318 CLAMP,HARNESS $4.05 1 $4.05
    92042-007 PIN-DOWEL $3.41 6 $20.46
    92043-1258 PIN,4X32 $2.62 1 $2.62
    92045-1304 BEARING-BALL (92045-1211) $6.28 1 $6.28
    92045-1024 BEARING,BALL,#6305SH2 $31.55 2 $63.10
    92045-1115 BEARING-BALL,6205 $16.33 1 $16.33
    92046-1052 BEARING-NEEDLE,AXK110 $7.71 2 $15.42
    92049-004 OIL SEAL SB12205 $5.28 1 $5.28
    92049-1051 OIL SEAL,TCJ25457 $16.17 1 $16.17
    92049-1052 OIL SEAL,TCJ20407 $13.83 1 $13.83
    92049-1207 SEAL-OIL,SDO8144 $5.17 1 $5.17
    92050-033 OIL SEAL TB3040 $11.02 1 $11.02
    92051-005 OIL SEAL,TB13225.5 $4.96 1 $4.96
    92059-1939 TUBE,6X9X500 (92059-1125) $8.25 1 $8.25
    92066-1241 PLUG $3.73 1 $3.73
    112BA0618 BOLT-UPSET (112G0618) $0.99 2 $1.98
    132BA0640 BOLT-FLANGED-SMALL (132G0640) $2.62 12 $31.44
    482J6000 CIRCLIP 6MM $0.99 2 $1.98
    600A1000 BALL STEEL 5/16' $0.99 4 $3.96
    601B6204 BEARING BALL #6204 $8.44 1 $8.44
    13031-1213 CRANKSHAFT-COMP $406.14 1 $406.14
    13008-5068 RING-SET-PISTON $43.34 1 $43.34
    13001-1039 PISTON,STD $77.48 1 $77.48
    92036-015 CIRCLIP-PISTON PIN $2.36 2 $4.72
    13097-1084 GEAR-PRIMARY SPUR,18T $88.87 1 $88.87
    59051-1049 GEAR-SPUR,WATER PUMP, $22.11 1 $22.11
    92022-1356 WASHER,16.3X29X1.75 $4.05 1 $4.05
    92015-1176 NUT,16MM $4.24 1 $4.24
    92002-1222 BOLT,6X10 $4.96 2 $9.92
    92015-1143 NUT-8MM $0.99 7 $6.93
    11001-1216 HEAD-CYLINDER $147.01 1 $147.01
    11004-1282 GASKET-HEAD (11004-1144) $41.58 1 $41.58
    46102-1156 ROD,GOVERNOR $40.29 1 $40.29
    92028-1413 BUSHING,5.6X10X14 $6.64 1 $6.64
    92066-1222 PLUG,12X10 $5.98 2 $11.96
    92065-073 GASKET-DRAIN PLUG $2.45 2 $4.90
    11005-1471 CYLINDER-ENGINE $563.77 1 $563.77
    92015-1415 NUT,10MM $2.62 4 $10.48
    32002-1838 FRAME-COMP $405.80 1 $405.80
    92015-1467 NUT,25MM,T=12 $18.34 3 $55.02
    11012-1256 CAP,STEERING STEM $3.73 1 $3.73
    92047-017 BEARING,STEERING STEM $24.77 1 $24.77
    92116-1008 BEARING,ROLLER,32006 $36.57 1 $36.57
    12005-1083 VALVE-EXHAUST,LH $36.54 1 $36.54
    92028-1389 BUSHING,6X18X5 $6.64 2 $13.28
    482J5000 CIRCLIP-TYPE-E $2.46 2 $4.92
    11060-1575 GASKET,CYLINDER BASE (11009-1546) $7.15 1 $7.15
    92043-1266 PIN,11X14X12.3 $0.99 1 $0.99
    12005-1084 VALVE-EXHAUST,RH $31.70 1 $31.70
    92004-1210 STUD $3.63 7 $25.41
    11009-1950 GASKET,REED VALVE $5.54 1 $5.54
    92022-1488 WASHER,8.2X14X1 $2.62 2 $5.24
    132BA0810 BOLT-FLANGED-SMALL (132G0810) $2.71 2 $5.42
    92037-1589 CLAMP,COOLING HOSE $10.61 4 $42.44
    39062-1105 HOSE-COOLING $9.01 1 $9.01
    12021-1058 VALVE-ASSY-REED $97.21 1 $97.21
    11009-1952 GASKET,ELBOW $2.82 1 $2.82
    11009-1953 GASKET,WATER PUMP COV $3.95 1 $3.95
    11060-1467 GASKET,CLUTCH COVER (11009-1548) $19.66 1 $19.66
    11009-1630 GASKET,GENERATOR COVE $7.80 2 $15.60
    13234-1062 SHAFT-COMP,WATER PUMP $40.29 1 $40.29
    13236-1141 LEVER-COMP,GOVERNOR $5.83 1 $5.83
    14024-1139 COVER,GOVERNOR $6.86 1 $6.86
    14031-1104 COVER-GENERATOR $57.30 1 $57.30
    14032-1208 COVER-CLUTCH $251.18 1 $251.18
    16115-018 FILLER,OIL $5.98 1 $5.98
    16142-1085 COVER-PUMP (16142-1067) $81.51 1 $81.51
    49114-1057 SHAFT-GOVERNOR $22.69 1 $22.69
    52005-0019 GAUGE,OIL LEVEL (52005-1055) $8.50 1 $8.50
    52014-1062 ELBOW $17.44 1 $17.44
    59256-1002 IMPELLER,WATER PUMP $25.52 1 $25.52
    92015-1078 NUT-6MM $1.87 11 $20.57
    92015-1572 NUT,6MM $2.45 1 $2.45
    92022-1393 WASHER,6X14X2 $2.68 1 $2.68
    92043-109 PIN $2.72 1 $2.72
    92045-1305 BEARING-BALL (92045-1212) $6.60 2 $13.20
    92049-013 OIL SEAL,SB18307 $8.08 1 $8.08
    92049-1366 SEAL-OIL,MHSD8X18X10J $10.23 1 $10.23
    130CA0520 BOLT-FLANGED (130P0520) $1.91 2 $3.82
    92002-1609 BOLT-FLANGED-SMALL (132G0625) $2.62 18 $47.16
    610A0408 PIN DOWEL 4X8 $2.71 2 $5.42
    11045-1379 BRACKET,SEAT,LH $6.68 1 $6.68
    11045-1380 BRACKET,SEAT,RH $6.68 1 $6.68
    14024-1287 COVER $10.67 1 $10.67
    35004-1181-6W FENDER-FRONT $83.35 1 $83.35
    35022-1230-6W FENDER-COMP RR L GREN $177.26 1 $177.26
    92001-1763 BOLT,W/SP,6X16 $2.71 4 $10.84
    92009-1347 SCREW,6X22 $3.11 2 $6.22
    92022-4017 WASHER $0.99 2 $1.98
    92027-1045 COLLAR $3.11 2 $6.22
    92039-4006 RIVET $0.99 2 $1.98
    92075-1153 DAMPER,SEAT $2.82 7 $19.74
    92075-1868 DAMPER $4.19 1 $4.19
    92075-222 DAMPER RUBBER,CASE $4.05 2 $8.10
    34003-1294 HOLDER-STEP-LH $26.75 1 $26.75
    34003-1295 HOLDER-STEP-RH $26.48 1 $26.48
    34028-1177 STEP,LH $42.94 1 $42.94
    34028-1178 STEP,RH $49.19 1 $49.19
    92001-4038 BOLT,10X44 $3.15 2 $6.30
    92210-1184 NUT,LOCK,10MM (92019-021) $3.46 2 $6.92
    92081-4027 SPRING,STEP,LH $4.54 1 $4.54
    92081-4028 SPRING,STEP,RH $3.99 1 $3.99
    112BA0622 BOLT-UPSET (112G0622) $2.29 1 $2.29
    130CA1225 BOLT-FLANGED (130P1225) $4.48 2 $8.96
    311BA0600 NUT,6M/M (311G0600) $1.08 1 $1.08
    11012-1211 CAP,UNI TRAK $4.24 2 $8.48
    32029-1438 BRACKET-ENGINE,FR $11.14 2 $22.28
    53001-1439 SEAT-ASSY $133.36 1 $133.36
    Subtotal: $6,166.25
    Continue Shopping
    Checkout
    Subtotal only reflects those items currently in your shopping cart. Sales tax, if applicable, and shipping will be calculated as you checkout. You'll be given the opportunity to review such calculations prior to you submitting any order.
    To increase the quantity of an item in your shopping cart, click on this icon next to that item.
    To decrease the quantity of an item in your shopping cart, click on this icon next to that item.
    To remove an item in your shopping cart, click on this icon next to that item.
    3848 N HWS Cleveland Blvd
    Omaha NE 68116
    Phone: 1-800-964-1882
    Phone: Local 402-505-4288
    Fax: 1-402-556-1796
    Email: customerservice@dillon-brothers.com
    Terms And Conditions | Privacy Policy
    Powered by ARI Network Services - WebsiteSmart Pro v1.6.10
    (c)2003-2010
    oregon
    668
    i have never seen a 1987 tecate for sale or owned i have seen many 86 85 and 84s for sale and im talking about a collector bike with very little hours.
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Even though the website shows the parts....many of those parts are DISCONTINUED.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    oregon
    668
    there was some discontinued parts but the box was blank so all i need to do is go to another website and get that part this one dont have.
    787
    Good luck on getting a new airbox and lid for it. They've been loooooong discontinued from Kawasaki. Those websites are just using Kawsaki's parts system and are getting their parts thru Kawasaki. If you go to Kawasaki.com and enter all the info for the Tecate...when you double click on the part #...it will more than likely tell you it's been discontinued. I've been doing the parts search dance for the '86/'87 Tecates for over 5 years now....most of the stuff is discontinued. That's why airboxes,chain sliders,right side radiator shrouds,seats,axles,tanks,overflow bottles......etc,etc are NOT available...regardless of what ANY parts website says.
    FZ
    oregon
    668
    well that sucks im sure if i end up doing this i could find people who have those discontinued parts i know there out there.
    i have seen some parts on ebay then theres a shops out there that might have used ones the only thing i can do
    is just fish for parts and restore them.
    thanks for the help.
    787
    What would be really cool is if Kawasaki parts dealerships had an interlinked search system that would allow each dealership to check each other's inventorys to see if any of those parts are still on their shelves. Sadly...there is no such system in place. Most of those parts have been purged from their inventorys.... being over 25 years old and all.
    Your best bet is to find the most complete,used Tecate out there and restore it from there.
    If there's anything that any of us on the 'site can do to help....just ask. There's plenty of Tecate owners out there that have been thru all of this before.
    FZ
    oregon
    668
    in portland theres a place called st johns honda.
    i have a 350x im slowly rebuilding and they have parts that havent been touched or moved since the 1985.
    once those parts are really hard to come by they charge a potload of money for them.
    another way to get kawasaki parts like u said would be to google kawasaki dealers and call them 1 by 1 and ask about their inventory.
    cause stjohns still has all the old parts on their shelves.
    but the hardest part of this is finding a 87
    i could check canada or europe like it says in the 87 search at 3ww homepage.
    alexandros is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Athens Greece
    283
    welcome to the club
    most of the parts in the inventory as Maico said are discontinued. And those who have them if they know what they have, they ask alot alot of money.....
    all the small thinks as rubbers,grommet, washers,scews are easy to find but its very rare to find a seat (last one new in ebay sold for 1000usd), colant tank, lighting bracket and many more parts.
    I own one 87 kxt and I will start soon one thread with the restoration. I have allready spend alot of money and still haven't find all the parts i need! I try to find parts for 3 years now...
    And the worse thing is that when you find one rare thing, it happens this period that you don't have the money to buy it and this drives you crazy....
    well I hope i didn't disappointed you and that you will start this project. Any help or advise I would be glad to help you
    Alex
    NY
    3,185
    Welcome 87 t3 enthusiast...I love the motivation but you are showing your a bit "green" (no pun intended ) on this one. I have an an 87 I have been collecting parts for since 2005 and have a TON of NOS goodies the I spent a mint on . Little by little chipping away at it. You will have a great time proceding but patience is key. You will not build this overnight and chances are unless your pockets are REALLY deep about 20K you wont be able to pull it off. When a super rare T3 part comes up....people spend. Most ....not all, dealerships have been scavenged by enthusiasts not just building the machine but those entreprenuers noting which parts go for cash and searching and flipping parts. I have sat down and called dealers. Many started after the 3 wheeler era and most of the olders ones dont want to chat on the phone....then you get the young parts sale rep say" We dont sell ducati" Good luck and if you need any help PM me. ( Oh there is the new 87 T3 Kawi opened up in that crate around 2 years ago at the ATV show)
    Quote Originally Posted by Orangecnty250r View Post
    If i had a nickle for every time I've heard that!
    Yep, I too did the whole dealer to dealer call thing a few years ago before I was on the boards. All I needed was a brake rotor. A freakin brake rotor!!! I called Kawi dealerships and used parts guy all over the country. It took me weeks to locate one and I paid through my arse for the thing. Sadly, as the other guys mentioned, most of those parts you're looking up are discontinued.
    Oswego NY
    1,935
    GOOD LUCK w/ the 87 T3!!
    I love my 87 T3, BUT its a rider! To me there is nothing like handing it to someone and saying ride it till it blows! The look on there face when they see I seriously want them to take it for a rip is almost as cool as the look when they come back w/ it. They rode a 87 T3!!! you can ask the guys and girls that have ridden it. (The only one to flip it was a girl!! But she had a shot of winning the mod class at TF09s drags w/ it!!)
    I love that part of the 3wheeler community.
    MIK6 / Mike
    New England Ride 4/13
    OK
    5,450
    Mike, I would rather have yours than a mint 87. Looks great!
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    oregon
    668
    i bet i could buy one off a 87 t3 owner for 8000$ if they want to sell it.
    Feb 2008
    Athens Greece
    283
    for 8000$ I would be surprized if you don't find a 87 kxt to buy!!!
