Results 1 to 12 of 12
Thread: Yamaha sport quad rims/hub on YTM225DX...
    unclejemima is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Canada
    197
    There has been some posts in the last few weeks of putting Yamaha sport quad rims/hubs on a YTM225DX.
    I just wanted to verify 100% this will work.
    I know the blaster hubs are 100% confirmed to work, but has anyone used anything else (Banshee, Warrior or Raptor?)
    Would the Banshee/Warrior/Raptor hubs be any stronger than the Blaster?
    In regards to rims, do all the named Yamaha sport quads use the same wheel lug spacing, or does each model vary? I was planning on getting a set of Blaster Rear hubs (they are cheap and easy to find) and then stock aluminum rims from a Raptor. Is this a good plan? Will it all bolt up?
    Thanks!
    Kokomo indiana
    80
    Quote Originally Posted by unclejemima View Post
    Thanks!
    there is a difference is the bolt patterns, the warrior, banshee, and raptor are 4-115 and are the same but the baster is different its 4 -110
    Sep 2006
    Dubuque,IA
    Blaster is 4-100. You could used tri-z rear wheels they have 4-100 bolt pattern.
    correct,, blaster/tri-z 4/100,,,
    warror/banshee/raptor,yfz ,all sport bikes are all 4/115
    they all will work but you have to use the right wheel/hub combo
    Oct 2009
    Canada
    197
    Ok, so the lug spacing is 4/100 for the blaster/tri-z and 4/115 for the others. Good to know.
    Has anyone actually used a hub from a warrior/banshee/raptor on the 225DX (or 200E). Is it a direct bolt on like the blaster?
    I think I will probably stick to a warrior/banshee/raptor hub/rim combo if it will bolt up. I would like to get aluminum if possible, and it is hard to find in the blaster as most of them I'm finding are steel.
    Thanks,
    Willamstown PA
    5,821
    i know banshee hubs are the same amount of splines are the 200x/350x, with that being said u should be able to run 300ex/400ex hubs on them to get 4x110 bolt patterns and widen it a little.
    i know this cuz a member had banshee hubs on a 200x
    Oct 2009
    Canada
    197
    Really good info. It would make sense that Honda/Yamaha would make something that is universal.
    Can anyone else verify this? It sure would make it a-lot easier to find rims if I could also source Honda hubs/rims for my YTM225DX.
    Thanks,
    Aug 2010
    web
    79
    Has anyone figured out if the honda hubs will fit on the 225? I actually have a set laying around my house, I will try this weekend if someone hasn't already debunked this.
    Nov 2007
    ulysses pa
    1,231
    Quote Originally Posted by Zuplar View Post
    WORN OUT 200x hubs will fit on, but you have to beat them on therefore, 200x, 350x etc will fit, as long as there worn.
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    Why worn out?
    Aug 2010
    web
    79
    Yes, well i tried non worn out hubs, and they did not work. Looks like only Yamaha hubs will fit. Picked me up a set of blaster hubs for $1, so I will be using those.
    Aug 2010
    web
    79
    well i did a hub swap. i put blaster hubs on, but then realized i had 400ex wheels lying around. so i ended up using the CNC to make some spacers/adapters. pics below:
