Will 200m forks fit on a 185s?
My ridez 110,110, Big Red, 185s, 70, 200, 250r!!!!
REQUEST YOUR ATC PART'S @ The 3 & 4 Wheeler Emporium
Should, there're basically the same bike
ok thank you.
They will fit but their for a 25x12x9 inch tall tire set up and a couple inches wider . 200s only uses a 22x11x8 inch tire set up .
so I will need a new front rim? and tire?
you shouldnt need a new rim and tire, just the axle and spacers from the M set-up I think! i dont know if the s rim is any narrower, just shorter, i may be wrong though
MY FEEDBACK THREAD- http://www.3wheelerworld.com/showthr...ight=aldochina
Also the M and the S have different wheel bolt patterns . the 200s is smaller .
Great. lol Guess Ill have to put that off for a while!
The 185 has less of a bend in the bridges. SO use the 200m top bridge, cause the 185 won't work on M forks and vice versa.
1985 ATC250ES Big Red, Low Hours,
1983 ATC185 200S jug, need crankcase or for sell
1985 ATC110 Stock, Hondaline headlight guard
1982 ATC70 Fun
IT'S A HONDA
