Results 1 to 15 of 19
Thread: Tires for MX
    jmack3986's Avatar
    jmack3986 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Lancaster, Ohio
    447
    Tires for MX
    What are the best tires to run for dirt on a 250R for like the PA Ohio and michigan area? i want to make sure i can hook up well.
    Oct 2009
    lindenwold new jersey
    890
    All depends on the track...indoors or out... heck I was running beat Razors at Summit and they were too much but your feet stuck to the track like a movie theater floor
    Maryland
    3,077
    18" tires get you nice and low and usually break loose easier than larger tires. It really depends on what kinda of racing you're doing. I would think GNCC would use different tires.
    Most of the MX trike guys like 18" fast trekkers.
    For real sticky tracks 18" carlise lawn mower tires even work well!
    jmack3986's Avatar
    Jan 2005
    Lancaster, Ohio
    447
    Yeah I'm running 18" tires but I'm not sure on the tread pattern. Most the tracks near me are wet disced and plowed so its kinda chunky. Im coming from florida though so I'm use to riding in sand just trying to see what is good all around.
    Oct 2009
    brazil indiana
    839
    are you running a TRX or ATC? it will be two differant tire setups between the two.
    Ontario, CANADA
    4,538
    Quote Originally Posted by Louis Mielke View Post
    IF your on a ATC, I have yet to ride/race on anything better than the trekkers.
    I have tried, lawn mowers, Turf Tamers, Razrs and the like....
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Maryland
    3,077
    Quote Originally Posted by jensenracing77 View Post
    Amen! The man knows his quads and his racing.
    Apr 2006
    PA
    1,464
    I run 18'' pirelli race rails on my 450 and know people who run them on trikes. I bought mine brand new for 32 bucks a piece. They wear like iron even on a 450 that spins constantly and hook up great. Seem to work good for a cheap tire.
    3leggeddog's Avatar
    Nov 2004
    Tires depend on the track,and even the conditon of that track.
    Hard packed tracks-1 grooved turf flamers work good
    2-Holeshot SX
    3-Maxxis Razors-Yellow label/pro compound
    Loose loamy tracks-1 ITP quadcross MX pro
    2 Maxxis Razors-either compound-grooved
    3 Holeshot MXR's
    Fronts-I like the quadcross fronts for any condition.Also the Yellow label Maxxis Razor's work well about everywhere.I just got a set of Razor Cross and will have a better opinion on them this summer.
    tires vary alot from track to track,and machine to machine.Rider taste has alot to do with it too.
    eddie pettengil is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    nh
    297
    What about 10 inch wheels for these 18 inch fast trekkers. Real low profile, wondering about the rim taking a beating. What would work good?
    Dec 2002
    Orange County, NY
    1,772
    I think you might want a little more sidewall than that. I don't see any of the quad guys running an 18 on a 10 and if it was a good set up I'm sure a lot of guys would be using it.
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Feb 2007
    nh
    297
    I think the reason the trike guys like the 10 inch wheel is for easier sliding. The quad guys use the 8 inch wheel to get more roll and grip out of the tire. This is just what I have heard. No side wall flex = less grip.
    Dec 2002
    Orange County, NY
    1,772
    Could be. I know a lot of the quad guys used to run Turf Tamers and shave a bunch of the knobs off.
    1986 Monstecate
    1984 ATC125M
    Oct 2009
    brazil indiana
    839
    Quote Originally Posted by JohnR. View Post
    cutting off some of the knobs on turf tamers will make them have much more forward bite. it don't help side bite all that much. the newer MX tires for quads made the turf tamers obsolete for quads.
    Dec 2002
    Orange County, NY
    1,772
    It sounds like you know what you have to do then.
    1986 Monstecate
    1984 ATC125M
