WRONG !!88-89 barrels are 5mm taller to accomadate the longer rod (125.3mmL for 85-87 and 130.3mmL for 88-89, same piston) This combo would not make a high compression motor.!! Sorry for the misinformation. I stand corrected, the part numbers are different but close. I was wrong.
More compression does not always work in a two stroke engine. In a MX style motor where it is not overrevved (much) and needs bottom end to pull you up jump faces more compression is generally tuned into the motor. Top end motors generally use less compression than a torquey motor. Trail tuned motors somewhere in between. If you use a high compression motor mainly for trail riding there can be issues with overheating on long runs with the r's up. If you can get a motor builder to tell you what they generally do then the consensus seems to be for a gasoline burning motor 9.5:1 captive for a MX motor and 8:1 for a top end motor. Simply milling the head is not the best thing to in some cases either. You can, by closing the squish gap tune in more MSV than required and this can lead to a chronic overheating problem too. Stock CR's are a little weak, but consider buying an aftermarket head or having your stock one reshaped or, at the least have your dimensions input into software and get a good idea of what changing the squish gap will do to MSV.
NEMPD.... soon
85 ATC250R 40whp
81 ATC450R Elsinore Hillshooter
K0 US90
If cleanliness is next to godliness and brake parts cleaner cleans EVERYTHING, is brake parts cleaner a gift from god?? Think about it.
