Doing my bottom end on my T-3 but having issues with the installation of the shift drums and the shafts.The manual states to make sure the trans is in neutral before installing the case halves together,but it is not clear on how the forks are placed into the shift drum.Does it matter where the shift fork goes on the drum?I have the gears and fork mounted properly on the shafts as per the manaul, but I don't understand if you just insert the drum, shafts into the cases so they fit, or is there a pattern to go by?
Thanks for the replies in advance!!
