Thread: Need help removing from axle from 84 Honda 200ES Big Red
    Jan 2005
    CALIFORNIA
    44
    Angry Need help removing from axle from 84 Honda 200ES Big Red
    I am having trouble removing the front axle from this trike and need some help. It looks like the axle goes through one shock through the other and is attached with a threaded nut. I removed the threaded nut and tried to rotate the axle with a screw driver (through hole in axle flange). It doesn't seem to budge. I also tried to drive the axle out with a (not too hard). Is it just stuck??? Any help on this would help me. Thanks
    Southern MN
    1,875
    It sounds to me like it is siezed, probly on the inside side of the bearring. It will most likely be a tough one to get off, especially trying not to wreck the axle. You may want to try penetrating oil, like PB blaster is the best, adn let it soak. After a thorough soaking, and it still dosnt move, heat is the next bet. The next step is beaking the bearrings out with a chizzel / punch. when you get the balls to fall out, the axle will come, but still poses two problems, one the races will still be in the hub, and still need to be removed, and two there is a steel spacer that will be stuck on the axle. Good luck with whatever you decide, and these are just starting points.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    COLORADO
    685
    Wouldn't the 84 have pinch caps on the axle? Stupid question, but I am unsure if the 84s had them. My 200 Custom does not have pinches, but the front end is off an 82
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    OHIO
    2,857
    here ya go.....http://72.52.143.80/~trikes/Manuals/...01984%20CD.pdf Got everything you will need to work on your wheeler.
    Jan 2005
    CALIFORNIA
    44
    Thanks guys I really appreciate the help
