I just purchased a singer lastnight. I have yet to have it running but the rear wheels will not spin freely. Curious if anyone has had this happen and if they can point me in the right direction.
the motor turns freely? , start with easy first,,,pull the clutch cover and inspect the clutch.
if all good then,, pull the rear end out.. check the shaft.. shafts good .. then pull apart the rear end..
That last trike I bought had the same issue, after beating my head around trying to find the complicated solution for awhile, I realized there was no complicated solution, the damn brakes were stuck.
If you can't fix it with a, its an electrical problem.
85 ATC 200s--Ratted out and not running at the moment
86 ATC 200x--All stock other than the handle bars
85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
I know a guy who just picked one up he is going to part it out if you end up needing somthing let me know.
Trikes
1985 Tri-Z 250 Piped ported and PV'd
1985 ATC 250R trail destroyer!
1984 ATC 70 rebuilding
1982 ATC 70 stut wheeler drag bar an cooler rack equipped
1973 ATC 70 searching for parts...
Bikes
2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
1988 KX500 The Beast!
1986 KX540 In search of parts!!! Help if you have some
1982 CR480 Unlimited Evo Racer
1982 CR125 Unlimited Evo Racer
1982 YZ100 cheater bike...
1981 KX250 Unlimited money pit Evo Racer
Sounds like the brake shoes to me . Let them sit to long they get stuck to the drum and get jamed .
