Results 1 to 13 of 13
Thread: 250R Front Brake Hose Rubbing
    Dec 2009
    Mountain Home, Id
    25
    The front brake hose on my 86 rubs the edge of the wheel. Does anyone else have this problem? Could it be routed wrong. It comes down the front of the fork and wraps around to the inside. It looks like it is right, but I could be wrong. I'm looking at getting a steel braided hose soon, and don't really want that to rub the wheel...any suggestions?
    1986 ATC 250R
    1999 XR 400R
    2002 Yamaha TTR-225 - FOR SALE
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    na
    5,702
    There is a clamp guide that bolts on the lower fork tube, and also another retainer that bolts on the caliper to keep the hose tucked tight to the fork tube.
    Do you have these on your fork?
    If not, it will rub.You will need to get the hose retainers to solve the problem.
    Here is the best pic I have showing the guide.
    Proudly NOT a member of
    "Team on the Teat"
    Dec 2009
    Mountain Home, Id
    25
    I have the clamp on the front of the fork, not sure about the one on the caliper though...I will have to check. Thanks for the reply...you wouldn't happen to have a picture would you?
    1986 ATC 250R
    1999 XR 400R
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    Dec 2002
    Orange County, NY
    1,772
    There is a bracket that attaches to the upper bolt of the front caliper and wraps between the fork and the wheel. Its kind of like a steel shell that covers the brake hose.
    It's #18 in this diagram. Its not a great shot of it but it might give you the idea. I can take a pic of mine when I go out on the ice today if you'd like.
    One thing I'd recommend when doing a stainless swap is to get some fuel hose from the auto parts store that has an I.D. just big enough to fit the braided hose into. Then cut off a piece the same length as the upper bracket that bolts to the fork, slice it lengthwise so you can wrap it around the braided hose and then clamp it in place. That will keep just enough tension on it to stop it from flopping around and chewing up your fork or fender or coming in contact with the wheel/tire. The braided line acts like a hacksaw when it comes in contact with aluminum or plastic. I'll snap a pic of it on mine if you'd like.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    na
    5,702
    I just uploaded a pic.Look above in my post.
    On mine, I never ran the caliper guide,and had no problems.The fork guide was tight enough to keep the hose in a fixed posistion.
    I will check If I have a pic of the caliper guide.
    EDIT!
    Yeah number 18 is the one you need that JohnR uploaded.
    It bolts to the caliper and runs behind the fork tube.
    Most guys do a front brake job,and remove that and forget to put it back on.That is probably what happened to you.
    You could always zip tie it tight to the fork tube until you get your braided hose set-up.
    "Team on the Teat"
    Dec 2002
    Orange County, NY
    1,772
    I have seen guys wrap a zip tie around the fork and hose to hold the hose down. Its kind of ghetto but it works. It'd be better to track down a proper guide but they seem to be NLA from Honda.
    1986 Monstecate
    1984 ATC125M
    na
    5,702
    The whole guide kit is usually on ebay for cheap.
    Try finding the ebay user Cycleguy1979 in Surprize AZ.
    You can contact him thru email, and he will sell parts outright without an auction for a fair price.He usually has that stuff laying around.
    "Team on the Teat"
    Dec 2009
    Mountain Home, Id
    25
    Awesome guys...you always come through! Gonna check mine, probably throw a zip tie on there until I get what I need. Again thanks for the info!!!
    Super nice looking trike MOSH!!!
    1986 ATC 250R
    1999 XR 400R
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    Las Vegas, NV.
    2,490
    Tufftoy, here's a couple pics of #18. I'm glad you're trying to route your brake line the right way. I've seen way too many 85-86 R's & 86-87 Tecate's with the brake line routed around the outside of the forkleg, which doesn't look sano at all.
    Attached Thumbnails Attached Thumbnails BL Guide outside..jpg   BL Guide inside..jpg
    Dec 2009
    Mountain Home, Id
    25
    Yeah, I doesn't look like have that little guy on there. Does it attach to one of the caliper mounting bolts? Went with the ol' zip tie trick this time, took it for a spin and it held, so until I can get a hold of one, so ghetto it is!
    Thanks guys!
    1986 ATC 250R
    1999 XR 400R
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    Las Vegas, NV.
    2,490
    Quote Originally Posted by tufftoy View Post
    Thanks guys!
    Yeah, the top caliper mounting bolt goes through the brake line guide, then the fork leg, and screws into the brake caliper mount. Glad you got it fixed, even though it's only temporary & ghetto. You gottta do what you gotta do to ride!
    Dec 2009
    Mountain Home, Id
    25
    You speak the truth my man!!
    1986 ATC 250R
    1999 XR 400R
    1984 ATC 200X
    1981 Yamaha YZ-80J
    1980 Yamaha MX-80
    Dec 2002
    Orange County, NY
    1,772
    Glad to hear its sorted out. I'm happier to hear that you don't plan on leaving the hose ghetto tied to the fork leg.
    John
    1986 Monstecate
    1984 ATC125M
