Results 1 to 15 of 18
Thread: 85 250r front forks.
    Side Wayz's Avatar
    Side Wayz is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    S. Jersey
    279
    How much fluid cc do i put in my front forks, and what kind or what am I supposed to use, and can I put directly in the vaulve stem or do i have to take the whole top off. Or what is the procedure.
    Thx
    Aint' no wayz like side wayz!!!
    84 200X (SOLD)
    84 250R #17 AirCooler Current Racer
    85 250R (in progress parts needed)
    Aug 2007
    Moab, UT
    1,807
    Jack the front end of the trike off the ground. There is a drain bolt on the bottom of each fork leg to drain them. Loosen the fork tube caps carefully because they will still have some tension on them from the fork springs. Flush the fork tubes with the drain bolt still removed. Stock replacement oil for them was ATF which is about 7.5 wt I believe. If you are a heavier or more aggressive rider, than I suggest putting 15wt in them. They take 400cc each.
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    Ok, thx. I guess it's pretty simple and not to hard to get the cap back on?
    84 200X (SOLD)
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    and how do I fill it up while caps are on tru the vavles with a syringe, just never did them. thx again.
    84 200X (SOLD)
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    Push the schrader valve in first to make sure there is no air pressure in them. Then take the cap off.
    Ninja, what do you suggest using to flush 'em out?
    And a red 2000 silverado
    "I" don't suggest ever flushing them out, why introduce contaminents into the fork system? To do it correctly, they get torn down, cleaned, inspected and parts replace; None of which are very expensive......
    Pour the fluid over the springs with a Pyrex cup/funnel or whatever. Just get the SAME EXACT AMOUNT in each fork.
    Thats why allot of guys pull the spring, push and lower the tube and add the fluid to a certain height from the top. Then you KNOW each side has the exact same amount of fluid............
    DC
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    everything is done, but its a lil squishy or soft, what are some options, the manual says 1 pound of air, but ive read previous post that air isnt good, and ive read about spacers. thx
    84 200X (SOLD)
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    Any 1 have any ideas thx.
    84 200X (SOLD)
    Aug 2007
    Moab, UT
    1,807
    DC
    Well, he wasn't asking about a teardown, just simply a fluid change. I provided the necessary information. When I suggested flushing them, I meant with fresh fork oil, then cycling the forks up and down several times and draining. If you change your fork oil a couple of times a year, this method will suffice.
    Ontario, CANADA
    4,538
    hey bud,
    you can try some progressive springs that will be your biggest help,
    but as a quick fix you can use anywhere from 1-3 PVC spacers and some heavier oil in them.
    I ran 2 seasons on prog springs, 1.5 spacers and some heavier oil and it was fine!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    Yeah that would be the biggest help (progressive) but money ismy biggest enemy now. Quick question whats 1-3 pvpi know what pvc isbut the 1-3 part.
    84 200X (SOLD)
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    1-3 inches.
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    I guess you meant 1-3 inches sorry.....and pvc will hold? Cool.
    84 200X (SOLD)
    Side Wayz's Avatar
    Sep 2009
    S. Jersey
    279
    Sorry, 1 more thing, I'm guessing to stick the pvc between the 2 springs?, cuz i have 85 front forks
    84 200X (SOLD)
    Ontario, CANADA
    4,538
    Yah PVC will hold, 1-3 inch pending riding style and weight.
    Put the PVC on the top of your springs, right below the caps
    #NOLINK
    #SUSPENDTHIS
