Results 1 to 12 of 12
Thread: swingarm bearings???
    krazykane is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    morrisville pa
    229
    hey guys i have a 87 honda 250x and the kid i got it from beat the hell out of the swingarm bearings so bad i can get the houseings out of the swingarm any but have any tricks up there sleeves to help me i want to get this up and running but cant get these dam things out .i know i could take it to the shop but what fun would that be .that is the lest option.
    Williamstown PA
    5,825
    use a tourch and a long socket and then punch them out. i never try and beat them out, normaly the stuff i buy is beat so i have somone remove them with heat. i will install the new ones myself with a large socket then.
    PA
    3,515
    some times it's best to just use a dremel tool and gring a line in the bearing shell, then it will pop out.
    WWW.HREATV.COM
    Feb 2009
    morrisville pa
    229
    i was thinking about doing the dremel but i will have to go get a attachment for the dremel .then i will try and let you guys know .
    London, Ontario, Canada
    1,059
    Not sure about the SX's but if there like the 250R's I just use a pc of 1/2" threaded rod, a couple nuts and some washers. you will also need a 1/2" drive socket slightly smaller in diameter than the OD of the bearings. I have also done this in a vice with the socket but it was a little awkward by myself. The pics show the progression of things.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    1,059
    The rest of the sequence.
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    My Wife's Ride
    My Kids Ride
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    Wow that is pretty slick! Thank you!
    1,059
    Works great on the R swingers with a bridge nice and close to the bearings, Wouldn't work on my tecate, all it wanted to do was spread the "arms" apart, had to switch back to the vice for that one.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    My Wife's Ride
    My Kids Ride
    Feb 2009
    morrisville pa
    229
    wont work on a 250 x because it has a solid tube where the pivot goes threw .but nice idea
    unclejemima is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Canada
    197
    RoscoW, very slick! Good to know!
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    i cut a line through them with a torch, they fell right out after that
    Feb 2009
    morrisville pa
    229
    well i used the dremel and cut aa line in them and then popped them out cleaned up the inside and pressed them in .thanks guys . hey anybody with a 300 x or a 250 x .can you tell me what the leasurement from hole to hole on the sprocket hub adpater .iam trying to get the right sprocket and the guy sent me one that dont fit .
