Thread: Stripping A Swingarm
    Mount Ephraim, NJ (sj)
    20
    I am building a 85R and want to strip the swingarm. I would like to polish it. What are the best method. Blasting or wire wheel? Or any other suggestions.
    6,803
    Paint stripper is what I use but just be carful . Not sure about polishing steel though , even with a clear coat it will prob still rust .
    20
    Do you think best to have blasted and pc
    Dec 2005
    Wisconsin
    1,141
    you will have to do a lot of sanding if you blast it. I would get a few cans of aircraft stripper and go at it the chemical way. It will be much easier to polish up vs blasting it.
    Edit: Use a good automotive clear so it holds up. Any chip in the clear and you will have rust.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Dec 2002
    Orange County, NY
    1,772
    I don't think polishing steel is going to work out so well for you. You're better off either having it chromed or powdercoated. I glass beaded and painted mine several years ago and its held up surprisingly well.
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
