Results 1 to 7 of 7
Thread: 185s clutch removal problem
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    I got all the clutch parts ordered on my 81 185s. Started tearing it apart today. Took forever to get the outside cover to break loose from engine. Then I started removing things from the centripical clutch to get to the large nut. After getting to it and getting the the bent part of the nut out of the dentation in the shaft I tried and tried to get the nut off but could not. I wasnt using an impact, may have to get one. This nut is left hand threads correct? I tried both ways. Finally gave up on it for the day. Any tips? Thanks.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Apr 2007
    UP of MI
    804
    You may need to get a strap wrench to hold the clutch case but if you can get ahold of an impact for a couple seconds of use, that would be the easiest. And you're correct, left hand threads.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    May 2009
    Wingo, Ky
    278
    I had a large prybar on the other side of the engine sticking through where the pull start goes wedged against footpeg. So it doesn't move much. I guess Ill just have to go at it with a impact. I didn't think it would be so tight.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Apr 2007
    UP of MI
    804
    Well, it's torqued to about 80 ft lbs and after sitting for a lot of years, it won't be easy to remove. Good luck though.
    1973 Honda CB350
    1973 Honda ATC70
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Baltimore, MD
    6,088
    The reason it is so tight is because of the peened area on the nut. The internal threads get quite distorted when those nuts are peened like that. An electric impact wrench works just as well as an air impact if you don't have an air compressor. Also a copper penny lodged between gears helps alot when you use an impact wrench and the copper penny won't mess up your gears. That prybar may bend up your pull start cage, be careful.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    May 2009
    Wingo, Ky
    278
    Thanks for the tips mopar man and vealmonkey. I borrowed my friend's 600ft.lb impact gun, took it off no problem. Glad I got that out of the way.
    Took everything apart and found out the centripical clutch drum is pretty much toast, no need in wasting 60 dollar new shoes in it.
    Where can I get a good drum or new one? The drum I have now looks like it has a bushing pressed into the back of it that rides on the crank or is that just part of the drum and would come with the new one? I don't see anything about it in any exploded parts view. Thanks.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Windemere
    33
    dont use a pennie i did that and it took out the oil pump drive in mine
