Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Trick Trike?
    lardog's Avatar
    lardog is offline At The Back Of The Pack Arm chair racerFirst time rider
    north san diego county
    172
    yes it is a bandito frame. Thanks for the other info.
    COLORADO
    685
    I am diggin that pipe, is it custom or an old aftermarket piece? how did you make the light guard?
    very slick little 90.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    lardog's Avatar
    172
    hi it is an old aftermarket powroll headpipe with a supertrap. The light gaurd is aftermarket also
    Feb 2009
    michigan
    2,387
    very cool take care of it
    1985 ATC 250R
    . Team Red Trike
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    Nice bike!I'm also curious as to what you have in the motor department?I like the cut out gear box.
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    lardog's Avatar
    172
    thanks, as far as the motor goes..the cc's are unknown. the motor came in a stock frame with low hours. i never opened up the motor to check the bore and stroke. its definatly built big and has high compression. It runs really strong for a little bike.
    6,811
    Quote Originally Posted by lardog View Post
    Thats def a nice motor and from the mods I see done to it it looks like someone put alot of time and money into it . The cases have def been split to do the sl90 tranny conversion so my guess is it might have a stroker in it to . Does the motor have any crank case breathers to relieve the pressures of the big bore EXC ?
    Go more I really dig the old atc90s with all the aftermarket goodies .
    lardog's Avatar
    172
    Thanks again ..I think it could have a stroker crank it has lot of torque as well as bottom end power and it tries to pull my arm off when i fire it up a breather was added to the top of the cases I have a bapp oil dipstick brather going on soon...
    6,811
    I see your new so welcome to the site .
    Their are a few of us that really dig these old 90s . I have a few of these motors done with large strokers and its pretty easy to tell if its stroked . While the motor is running they sound much different than a stock crank and more like a 200x . The added breather is def a sign that is possibly stroked . The BAPP breather is a nice piece of bling .
    posty2100 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    PA
    336
    thats one badasss 90!!!
    lardog's Avatar
    172
    Thank you..
