I have an ATC 90 that I recently rebuilt with all new electrical parts, piston, valves and springs. My problem is this: It seems way too rich (it blows black smoke, cuts out when you open the throttle, usually won't even come off idle, plug and combustion chamber is all sooty). It seems like the centrifugal advance isn't working or something. It seems like it can't burn the fuel, or is firing at the wrong time. I think the timing is set right, jetting does not help any. It runs the same whether you run a 90 carb and intake or 110 carb and intake or shorty filter or an airbox with stock filter or any jetting combination.
One thing I thought: The current head had the plug hole stripped and resized to a standard sized plug. I thought maybe the re-machining had messed up the shape of the combustion chamber or maybe the flame propagation was messed up or maybe the spark was now in the wrong spot. I bought a stock ebay head, but I have yet to try it b/c I am so frustrated.
FYI, Im running a BBR knock off pipe.
Does this sound familiar to anyone?
