Results 1 to 10 of 10
Thread: What year is my 200x?
    Worcester, MA
    1,117
    I just picked this up for $100.
    Also came with front forks, tire was nice looking.....except for the cut through it. I believe it was some oddball size, not the same tire that I have on all my other ATC's.
    I tried reading the vin, but it's pretty much illegible. My best guess would be:
    jh3tb052x1k402998
    Running it through the vin decoder, it comes back as: Decoding Results: Unknown Year ATC 200x
    I'm going to start getting parts for it, but I need to know what year it is as apparently the 200X parts are different for earlier and later models.
    I'll probably put my 200s engine in it. It turns over and has spark, but it seems to have low compression. This is strictly a guess on the basis of me being able to push the kick starter with very little force (with the plug in.)
    Thanks
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    83-85 200x hense the round frame, all 83-85 parts interchange and an autox is a good idea
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    Santa Barbara, California
    1,161
    1985, it has a square swinger and blue shock.
    1985 Honda 200x
    Worcester, MA
    1,117
    Alright, thanks a bunch. I suppose I need a seat, I can always use a mini-gas tank for temporary use.
    Going to need the front brake + mounting assembly, a few bolts for mounting the forks, new front tire, and bars.
    I figure my running engine + rear tires from my 200s will fit right in and I should be able to ride this within a day or two.
    I may eventually get this engine going for the manual clutch. It may be funner to play on, but for trails I'm thinking the auto clutch would be better. Sad to think, a month ago I hated the idea of an auto-clutch......
    EDIT: Wow, just my luck. Find a $75 parts bike with stuck motor, except its a 1986.
    Willamstown PA
    5,824
    1985 based on blue shock
    Des Moines, IA
    1,303
    I'm not sure, but I think it might be missing some parts!
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Willamstown PA
    5,824
    If you need parts i got a bunch cheap
    Jun 2009
    Tunkhannock,Pa
    904
    definitely 85
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Apr 2006
    SE CA Dez in the sandbox
    899
    something's wrong about the 10th digit of the VIN. That digit indicates the year. Swingers and shock boots can be changed.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    Worcester, MA
    1,117
    Thanks, will be needing some.
    Quote Originally Posted by RapidRick View Post
    That one was very hard to read. I basically can see a very small part of it.
    Looking up year codes and comparing with the VIN decoder, if I change my tenth digit of the VIN to 'F', then it says 85 atc200x.
    I can't see enough to say whether or not for sure it is an 'F', but that is the year code for 1985.
