Results 1 to 15 of 23
Thread: pitted cylinder head?
    Nov 2006
    saratoga, new york
    9
    Is this going to cause hot spots? There are chunks missing out of the head all over and a couple pieces of aluminum or some type of metal are stuck to the head.A few of the chunks missing are pretty deep. I'm worried about using this on an engine i'm about to dump a bunch of money into.
    Personally, I would run it. There may be some people on here that have run something like this before and can chime in.
    OK
    5,450
    From what I have read and heard, those gashes will create hot spots which will cause preignition, detonation, or pinging. This will create more damage to the inside of the cylinder head and piston crown. Your best bet would be to take some emery cloth to it to smooth out the roughness.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Oregon
    2,471
    I wouldn't, Might be able to clean it up. ( I think Ronnie does this type of work )
    Do a search ...
    Y'know, on a second look I don't think I would run that. It probably wouldn't be too hard to smooth out.
    Sep 2008
    Northwest Indiana
    550
    With the right set up on a lathe.....you can spin it out!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    1,736
    my buddy's banshee was like this, he smoothed out the chunks that stick out with a drummel. runs perfect
    Racerguy381's Avatar
    Racerguy381 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Puyallup, WA
    265
    Lower end bearing failure is what caused that damage.... If you smooth it out it should be ok, but recutting it in a laythe would be the best way to fix it. Or just find another good head. I would really tear into the bottom end if that head came off the motor like that...
    Trikes
    1985 Tri-Z 250 Piped ported and PV'd
    1985 ATC 250R trail destroyer!
    1984 ATC 70 rebuilding
    1982 ATC 70 stut wheeler drag bar an cooler rack equipped
    1973 ATC 70 searching for parts...
    Bikes
    2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
    1988 KX500 The Beast!
    1986 KX540 In search of parts!!! Help if you have some
    1982 CR480 Unlimited Evo Racer
    1982 CR125 Unlimited Evo Racer
    1982 YZ100 cheater bike...
    1981 KX250 Unlimited money pit Evo Racer
    1,736
    yeah, theres some cheap stuff on ebay, thats what i would do if it was mine.
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    It could probably be run, and could be fixed but I personally wouldn't run it at all. The question is, is it worth fixing? A machine shop is gonna charge you way more than a nice head head would cost. Unless you know a machinist, or it is a rare piece.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    Aug 2005
    Lockport, NY
    2,395
    Ronnie, AKA Yamahondaman, can definitely fix this for you. Cheap if I remember right. Contact him. Here is some work he did for me.
    Before
    After
    Dec 2002
    Orange County, NY
    1,772
    I've seen a bunch of Ronnie's work (mostly parts that he machined) and its top notch!
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC125M
    Jun 2009
    Tunkhannock,Pa
    904
    for the love of god get it cleaned up before you run it
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Jun 2006
    Illinois
    491
    I wouldn't run it either. Ronnie's really good, have him cut it for you or get another one.
    Jan 2004
    Palmetto,Florida
    2,300
    Contact me .. i'll hook you up ..
    Ronnie
    "07" DR650 Suzuki Dual Sport
