I'm in the process of swapping motors in my 86 250sx. I'm learning as I go so any help is appreciated. The final drive has been leaking oil so I removed it while I had the motor out to find the leak. It turned out the drain plug was the problem. Should have checked it closer before removing the rear axle/ect. I noticed that when I held the final drive case vertically, drive shaft pointing down, a small amount of oil would trickle out. Does anyone know if this is normal or is there a seal that needs replaced. I have a service manual, couldn't find any info if this is to help with lubrication of shaft or not.
