Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: anyone think they can solve this?!
    Chalk River Ontario
    27
    my problem is my 1983 atc110 ran perfect for about 3 weeks since purchase. Then it started dirtying the plugs really black but if you changed it with a warmer used one or new one it works, but i have been using all the fouled plugs just rotating them and tossing in a brand new plug at times so i know its not killin them this has been happening for about a week. THEN! it wouldnt start!??! when i finally got it to start it would idle and aloooot more smoke was coming out and i couldnt touch the gas at all, when ever i gave it gas in neutral it would backfire and pop...then bog....then die. So we finally just kept letting it warm up and idle and i tried driving it in low gear. If i give it anymore than 15% throttle it bogs pops and dies...or if i put any load on it (say going up any hill) it bogs and dies as soon as i have to give it gas. SO did some research found out to clean the carb, so decided to do so. When we took the carb off i noticed a bit of gas in the tube leading to the air filter i didnt bother with it. I then cleaned the carb taking ever last bolt out EXCEPT the choke, i didnt play around with it. I scratched some markings and counted my turns of each screw, there is no holes in the float, there was some gunk, but nothing clogged, i put everything back together exactly. i reinstalled the carb, started maybe 6th pull, screwed with the idle and got it running GREAT it was running awesome then we let it stop for about 5 minutes, wouldnt start, changed the plug, it idled but wouldnt move again.....so went back to cleaning the carbs did everything i was suppose to do, and no luck again, drove around in low but not more then 15% throttle. so got tired of it then today i tried starting it and it wouldnt run. So i decided i was going to check out the "intake" situation and i noticed gas! so i took the tube off and found out that gas was spraying out below the choke (i think from the valve below the choke) it wasnt like a spray, more of a sputter. And that folks is why i joined lol does anyone have any ideas, i dont understand this :S lol thank you for checking it out guys, i appreciate any help possible.
    Oct 2007
    Minneapolis mn
    4,067
    Cleaning the carb may not be enough... Sounds like you need a rebuild kit for the carb and choke.... Float sounds out of adjustment. And is the choke, a small piston enrichment style of choke?
    Chalk River Ontario
    27
    well i know that all my gaskets on the carb and the filter in the pump are in good condition, i did notice when ever i gave it gas the spring on the choke(where you open and close the choke) would....flutter?....i guess you could say. The lever it self wouldnt move when i did that just the little spring and the little metal piece on it.
    Baltimore, MD
    6,088
    If you look down the intake side of the carb, there should be a small metal "window" and that will flutter back and forth, that is normal. Then you should have your choke lever and that should move a larger metal "door" that also has that window as part of it. What you want to check for besides your carb is wether or not your airfilter is dirty. If the filter is dirty, then you will have more fuel than air than you normally should have. Also a carb rebuild kit will have new fresh gaskets for the carb. Even though all your gaskets may look ok, they are possibly as old as the trike and simply all squished down and dried up and can let air in sports you don't want air. When you had your carb apart you should have checked you idle jet and main jet to make sure they aren't clogged. Not only do you want the middle of the jets not clogged up which is easy to see, but you don't want the little holes on the sides of the jets clogged up either and they are way harder to tell that they are not clogged up. Also you want to check where the "e" clip is on your needle that goes down into your main jet. It should be in the middle of the 5 rings. If it is in one of the lower 2 rings, it is probably letting in too much fuel too soon. You also need to make sure you have good gaskets in between the carb and the intake to the head and between the intake to the head and the head. In between the intake to the head and the head, there should be an plastic insulator as well as an intake gasket. The insulator is there so the intake doesn't get to hot from being in contact with the head. On the back of the carb, there should be a place for a rubbe o-ring, that should be in place. I make sure that I run the o-ring and 3 gaskets between all the mounting points where there could be an air leak. It's a little overkill, but it beats banging your head over a small air leak which may make your trike run all kinds of crazy. Also on your idle needle and your fuel and air needle, there should be small o-rings, if not, that could be a problem. A carb kit will have all the o-rings that you should need, the intake gaskets will have to come from a engine gasket kit or you will have to buy some gasket material at the local auto parts store and you can make them your self with a marker and a sharp knife if you take your time. You also could have valve adjustment or timing issues but one step at a time.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2009
    Chicagoland
    318
    That (sputtering gas)? Sounds like a simple vacuum leak! Also, old gaskets tend to decorate, then gas hits them again after drying and breaks little particles away, causing clogged jets! Just a couple of things that were my problems, with the same issues!
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by rickybudz View Post
    I think Ricky means deteriorate, not decorate... No balloons and streamers....
    Feb 2009
    michigan
    2,387
    id like to see your plugs.wet and black?dry and black?what color was the smoke?if the plugs are dry and black you have carb issues.
    1985 ATC 250R
    . Team Red Trike
    Chalk River Ontario
    27
    Hey thanks alot guys, appreciate the help. I checked those gaskets and from the cylinder to the carb. nothing at all is damaged they actually look quite new, i dont know when they were replaced because i never asked the guy i bought it off of lol but the throttle needle still has its o-ring, its all good. I cleaned every hole in the jets thoroughly. As for the plugs, wet black, sometimes not wet. the smoke is white. I just recently tried seeing if it was because it wasnt getting enough gas so i sprayed some gas into the cylinder and put the plug back in, started no problem idle till the gas burnt out and thats it....FML lol so is there anything i can try before i get the carb kit?...
    Aug 2004
    Ab Canada
    4,368
    Did you get some snow/water in the tank? from filling up...or an iced up air filter....? a little bit of water is all it takes....Check the oil for it too....
    1985 Tri-Z-
    Chalk River Ontario
    27
    no water or ice any where to be seen.... i cant figure this out lol im trying to get it going as fast as i can cuz i wanna trade it for a 440 motoski ultrasonic. But besides that, ive noticed the choke when idling does little or nothing to the bike, its almost like the choke doesnt work at all. Also on my choke is there suppose to be a cap on the choke lever? i can see the spring and little metal stuff. im gonna take pics of the carb and post them apart and intact, again thanx guys
    Chalk River Ontario
    27
    i dont know what the screw on the left bottom side of the carb does, heres some pics of it, also i just made a vid, ill try and put it on youtube and get the link for you guys. thanx
    May 2007
    Orange County, NY !
    1,672
    Is the float stuck? Or maybe it is not sealing properly, and you need a new float and needle.
    Chalk River Ontario
    27
    Well ill check that all out, heres a video, maybe the sound of the machine may help i dunno anymore, im gonna kill myself soon lol http://www.youtube.com/watch?v=5Id4TI4Fa0U
    May 2007
    Orange County, NY !
    1,672
    Dude, it's getting flooded. The float is stuck, and you will have to rebuild the carb. If the needle doesn't seat, the one attached to the float, gas will pour in to the carb and intake, giving you a black plug, and flooding it to the point that it won't start.
    Whenever your bike doesn't run, you check for three things immediately:
    1: spark
    2: fuel
    3: compression
    Did you do a compression check?
    Chalk River Ontario
    27
    if it is flooded, how come when i spray gas into the cylinder head it starts it wouldnt if it was flooded that make it even more flooded and for sure not start lol and also when i took the carb apart and put the float back together the float would EASILY move up and do, it seemed like it had good movement, what could cause it to get stuck. also i am doing a rebuild just waiting for the parts and i will do a compression test today. thanx alot again!!!
