turbo, in a way you answered your own question. But pump gas shouldn't be a problem at 10.5:1. And the powroll does have a sllighty higher dome than the old tucker rocky pistons. I remember you asked about shaving the head. The 2 big problems with that are 1, once you shave your head and add a domed piston, valve and dome clearances become super critical and 2, sometime shaving the head or cylinder can have bad results with the overhead cam chain. Now you sound a tad bit more knowledgeable than the some of the people on here. So I'm thinking that you have dealt with piston and valve clearance types of issues before, maybe many times before, so that gives you a major leg up on some of the people on here. But there are people on here who would shave or deck their piston and cylinder or have them shaved or decked and then install the piston and put it all together without checking and then have disasterous results. Obviously you have engine building experience under your belt. But, before shaving or decking or however you would like to refer to the operation as, please check your clearances beforehand and see how much you have to work with. With manufacturers tolerances and 30 year old engines and aftermarket gaskets, your margin for error may be quite slim. The average person on here who is putting a new piston in a 90 on here is not really gong for performance gains and is just trying to get a fresh bore and piston. There are a couple people on here who dabble with old 90 power. There many neat tricks to do to a 90 engine. Motorcycle pistons and all kinds of other magical things. But the main reason I believe that you are not getting alot of responces is that not too many people do these kinds of things. You know how to cc a head. I would take it that you know how to "blueprint" an engine then. Your best bet is to blueprint your 90 engine out. Matchport your intake to your head. Polish your inlet port and exhaust port. Beware of opening up your exhaust port, as this will more often than not kill what little power your engine has. You can balance your rod and piston if you so desire, it will add a little extra power. I know people who have redcoated the insides of their engine cases. I know of people who thermal coated their pistons. Some people wrap their exhausts. Some people vent their heads, highly recommended on engines that will constantly turn high rpms. Remote oil coolers and way more crazy and anal mods. But you also listed that you are mainly using the trike to pull an ice shed if I remember correctly. You really need a cam that makes your power on the low end for that or so I would think. But really I would think that a larger engined trike would work much better for that, in my opinion anyway. I"m not trying to discourage you in the least. If you remember I was the one that suggested that you get your trike in top notch running condition first and then go from there. The 110 carb and intake was one of the most simple and at the time economic hop ups to perform. Now that parts are 30 years older and harder to find, it's a tad harder for that to be an easy mod. You can still find aftermarket intakes and larger carbs, but it's a tad bit tougher to find them and a larger carb only works well with a cam, a larger piston and a better filter and exhaust. And the majority don't really want to spend the time and money when it's easier to just get a larger displacement trike. If you are wanting to go crazy, having your cranked stroke and running a sleeve and a cb750 piston is starting to get you in the ball park for serious 90 power. Changing engine cases is highly recommended so you can get rid of the hi/lo gearbox and go with a manual clutch. But I'm not sure how crazy you really want to get here. But there are tons of mods for the dedicated.
Oh, and before I forget, the poor guy is just selling pistons, not performance advice. LOL
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
