New to this...Just bought a yt60 and can't get it to pop...PO said he put new rings and piston in...Took silencer off and seems closer than ever to starting, but sill nothing...Thanks in advance, Jim
HUH?
It's gettin' spark...
HUH?
You got the right plug? If so how new is it? Anytime my zinger has a hard time starting its the plug.
85 350x 12:1 piston and porting by "boosted96cobra"
4 85 tecates 1 runs
5 84 tecates none run
1 84 Yamaha Zinger, mildly ported & polished, milled, bored .25 over finally running
2 atc 90's just parts bikes
00 rm250
93 kx500
2 Honda 200m parts bikes
Fresh plug, and make sure your exhaust is open... The expansion chamber is very prone to plug on the zingers.... Simple fix is to pull the silencer off, and take a half inch drill bit, and drill into the expansion chamber. (there is a mesh screen in there that gets plugged with carbon) A half in ch hole will eliminate that problem. Also, make sure your silencer is clean... Had to take mine apart and burn the carbon off with a LP torch, and scrape the crap out... Ran like a dream then...
I will be trying all of these today...my back is killing me from trying to pull start the thing. Will keep everyone posted, Jim
HUH?
