View Poll Results: To Slime or Not to Slime
Voters
193. You may not vote on this poll
  • Ride
    17 8.81%
  • Keep it safe in garage for collection.
    0 0%
  • Ride safely with no stupid ideas in mind.
    11 5.70%
  • Yes
    8 4.15%
  • No
    4 2.07%
  • Just buy new ones
    4 2.07%
  • 83-85 200x
    4 2.07%
  • 86-87 200x
    11 5.70%
  • 85-87 Honda 350X
    13 6.74%
  • 86-87 Honda 200X
    6 3.11%
  • 85-87 Honda 250R
    11 5.70%
  • 85-86 Yamaha Tri-Z
    2 1.04%
  • 86-87 Kawasaki Tecate
    3 1.55%
  • Good Deal!!!
    1 0.52%
  • So So
    9 4.66%
  • Sucker!!!
    5 2.59%
  • 1985 Honda 350X $950
    12 6.22%
  • 1987 Yamaha 350 Warrior $850
    3 1.55%
  • Red
    2 1.04%
  • White
    4 2.07%
  • honda
    0 0%
  • yamaha
    0 0%
  • kawasaki
    1 0.52%
  • suzuki
    3 1.55%
  • polaris
    10 5.18%
  • bombardier
    5 2.59%
  • Yes
    6 3.11%
  • No
    5 2.59%
  • Freddy
    5 2.59%
  • Jason
    10 5.18%
  • Alien
    2 1.04%
  • Predator
    4 2.07%
  • Best Invention since ATC
    10 5.18%
  • I'll Pass & walk home
    2 1.04%
Results 1 to 12 of 12
Thread: To slime or not to slime
    mkramm is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    224
    Does that tire slime stuff actually work? I hear its a bear to clean off when you change the tire though?
    Feb 2003
    Delano, CA
    616
    I used it on the front tire of my 79 110. The person who had it before installed a round type tire patch. It didn't really work to good after a week, and the hole was a good size. I left the tire patch in it. The tire is old and is like a 25 inch tire now instead of a 22.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Lots_Of_Nothing's Avatar
    Lots_Of_Nothing is offline So bombed at TF I needed both hands to hold my beer Teaching quads a lesson
    Upstate NY
    2,665
    this stuff kicks a@@ i have used it tons of times, and it works every times, its not hard to clean off, just hose it off, and it comes right off
    Give me no lip and I tell you no lie.
    -TF 05' , And cant wait till 06!
    Fresno Ca
    2,695
    the fix-a-flat is good if you need a quick temp fix for a weekend or so. ive never used slime tho
    Clarks Summit PA
    1,236
    but at high speeds it causes wheel wobble.. i have used it a few times, and it has sealed leaks.. but running 60-70 mph.. it sux!!
    Ride it like you stole it! And never look back! They are too far behind to see!
    Howdy's Avatar
    Celina, Ohio
    10,079
    I cast the only "No" vote. I hate slime with a passion. I have changed a lot of tires with it in and it is messy. While it might get you a quick fix to get by, it makes the person having to change or repair the tire job more work.
    I have gotten a few tires in that has had slime in them. Some of these tires had 1/2 tread or so. Instead of removing the tire I burned them ( if they were on Steel rims ).
    Howdy
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pyro Howdy!
    I have use slime once in my pedel cycle, it didn't work, the tyre went down, brand new tube that came with slime already in it got a thorn in the tyre and it went down :?:
    I now use OKO Linseal, its made here in the UK, I don't think you can get it over in the US, but it is excellent, expensive but worth it, I have it in all the tyres on the 110, pedel cycle and my riding mower and the 70 has it in, the tyres never go down, it is based on linseed oil and it gree with little bits of black rubber particles in it, these bung up the hole, the last time my pedel cycle tyre went down is because the tyre and tube split on a peice of broken glass, when I examined the tyre and tube there was over 20 thorns in the tyre puncturung the tube, I can't say it doesn't work.
    It is a trailprotrailprotrailprotrailprotrailpro to clean up with paper if you spill it but will hose away ok if outside.
    Nat
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    Roanoke, VA
    4,038
    Slime is like Duck Tape....you can't live without it.
    The key to slime is that right after you fill the tire up...you have to drive around a while so the slime can be dispersed equally around the tire so there is no wobble (there will be some...but not nearly as much as if you let it all settle to where the hole is) Yes slime is messy...but you wont care when you are 10+ miles away from the nearest place to air-up or fix it.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Southern MN
    1,875
    It works pretty good if the hole in the tire is rather small. I have used it a few times. I dont think its too big of a mess. I just wipe it out with a rag. Its a lot cheaper to buy a bottle of slime, than to take it into a tire shop to have it patched. One thing I like about slime is that if you run over a nail or something and get another puncture, the slime will still seal it up. In the long run, slime is a good thing to use.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Apr 2003
    Bay Area CA.
    2,638
    Yeah ATC crazy is right, you have to ride it for about two miles so the slime can spread around on the inside. I have a question can you put slime in a tubeless tire?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Feb 2003
    Delano, CA
    616
    Quote Originally Posted by Honda atc70
    Yes, just make that slime your buying is ment for a tubeless tire. They make 2, for tube tires and tubeless tires.
    2004 TRX450R
    krizo88's Avatar
    krizo88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    297
    I tried that slime in my 85 R and I will never use it again. It feels like i have a 5 pound weight sitting in the bottom of my tire. I used it to seal some leaks after I removed studs from my front tire. I used as much as recomended and rode for around 2 hours, it seemed to work ok untill the next day I took it out for a ride and the front end vibrates all over the place. Now I have to buy a new tire. So I would rather walk my happy arse home than go through this again.
    1985 TRI Z
    1985 ATC 250R
    2004 YFZ 450
