You have to use a C clamp to push the piston back into the caliper, it is out too far from the brakes being worn out. Put the clamp on either the inside pad, or remove the pads and press on it directly, until the piston goes all the way down, then your pads will fit right in, and you will be able to assemble it. On the bleeder screw, you should hold in the front brake lever while you crack it open with your other hand. Watch out so it dosnt spray you in the eyes. If you try squeezing and cracking, and nothing comes out, the bleeder screw itself might have some dirt in it, blocking the fluid. If this is the case, you will have to try to replace the screw, or clean it. Make sure you take the cap off the resovoir at the bars, and keep an eye on the fluid level so it dosnt get too low while bleeding the system. Sometimes pumping the lever, holding it, and cracking the valve dosnt work, and you will have to find a mighty vac, or suringe to purge the system. Good luck, try the above and see what happens!
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
