Thread: MX wheels (need Info) for fast trekkers
    eddie pettengil is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    nh
    297
    I'm getting ready to try some mx racing in Maine this summer. I have a set of 18x11x10 fast trekkers and I need to find a good wheel to match to the tires for the rear of a "86" 250R. I'm hoping I can get a wheel with inner and outer reinforcing rings.
    The only thing I have found is the ITP T-9 Pro Series Baja wheel (10x8) but the 10 inch wheel only comes in a 8" width. Will the 8" width of these wheels work with the 11" width of the tire.
    The only other wheel I found was a Douglas .190 (10x10). These do not have the reinforcing rings but have the 10" width.
    Do I need a 10x10 or will a 10x8 work for a 18x11x10 tire. Thanks
    Apr 2009
    Western, CT
    139
    I use to run 8x8 itp bead locks on my trx with 18x11x8 holeshots with no problems.
    Racerguy381's Avatar
    Racerguy381 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Puyallup, WA
    265
    You dont need to be running a 10" wide wheel with that set up. With your tire stretched that far you wont have hardly any sidewall flex plus it will make your rim more prone to getting smacked and bent. 10x8 is the most common size with an 11" wide tire. Next if your looking for bead locks I sell alot of the Douglas OMF bead lock wheels. If you want to get really trick you can buy the billet center OMF bead locks
    Trikes
    1985 Tri-Z 250 Piped ported and PV'd
    1985 ATC 250R trail destroyer!
    1984 ATC 70 rebuilding
    1982 ATC 70 stut wheeler drag bar an cooler rack equipped
    1973 ATC 70 searching for parts...
    Bikes
    2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
    1988 KX500 The Beast!
    1986 KX540 In search of parts!!! Help if you have some
    1982 CR480 Unlimited Evo Racer
    1982 CR125 Unlimited Evo Racer
    1982 YZ100 cheater bike...
    1981 KX250 Unlimited money pit Evo Racer
    N.E. Ohio
    2,005
    .....post quote from raffa
    FastZ28's Avatar
    FastZ28 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    Jonestown,PA
    228
    I am using the same size tires with Douglas 10X9 .190 wheels, so far mine are holding up well. No reinforcing rings.
    84 Z28 Camaro
    94 Caprice 9C1
    02 2500HD Silverado 4x4 ext cab
    84 atc70
    85 250R
    87 Big Red
    90 VTR 250
    Feb 2007
    nh
    297
    Thanks for the replies guys,. Does anybody know where I can find the Douglas 10x9 wheels with reinforcing rings.
