So I picked up this 86 250r the other day for $500 because I wanted an "R" so badly. I was pretty content with my purchase even though I knew I probably didn't get a great deal and that I would need a lot of money and a lot of time to make this thing a rider. As I dug into it more today I kept finding things that made me realize I probably made a pretty terrible purchase but what is done is done so I'm jumping head first into getting her back running and running solid.
I pulled the engine today and found a few things that really concern me so I'm asking your opinion.
1. There are two studs missing for the cylinder. Are these replaceable or do I need a new case? Please say I can replace them.
2. There are two broken spots on the left side case for the piece that covers the front sprocket I assume. How big of a deal is this?
3. When I was pulling the engine I noticed that it is worn all the way down through the case where I can actually see the front mounting bolt. Does this area go all the way into the bottom end or is it drilled out just to house that bolt that attaches to the frame mounts? Am I still looking at a new case because of this?
On the upside I did find the carb and it appears to be in pristine condition. It looks like I'm going to need everything for this. Brakes for the front and rear, levers for the front and rear, twist throttle or thumb throttle etc. etc. I did get a seat in okay shape with this one but it will need recovered at the least and maybe new foam. I also got a tank that is in good shape but I didn't get any kind of fenders.
So for all you experts... Where do I start? How bad did I screw up? I'm still excited for this project but I guess I just need some encouragement as well as some realistic answers as to what I can expect with rebuilding this engine. Thanks in advance for any advice, gripes, or comments.
Here are some pictures:
