Results 1 to 12 of 12
Thread: sx vs es differential. what is the verdict?
    Mar 2003
    Australia
    1,919
    After looking on here for ages as to if the sx has a higher geared rear differential than the ex, I could come up with nothing. Everyone was so unsure. Just wondering now if anyone has a better idea on the matter. Is the diff the same as the es or is it higher geared? Would be great to put one into my es.
    Thanks guys.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Apr 2002
    s.w. michigan
    6,498
    I like my Bigred with the sx differential. I done the swap 3 years ago after one of Sandpuppys rides.
    It was up on the long straight trails I realized I needed just a tad bit more top end speed and I got exactly what I wanted by doing the swap.
    What I learned in was that if you have a 85es, you will need to use a 85sx differential. Same with if you have a 86, you need to use the 86 differential. Then it will be a direct swap out.
    Dose it make a huge difference, no. I can only describe it as moving up a gear all around.
    Creeper first gear is still a creeper first gear, just a little bit taller so to speak just like the other 4 will be.
    Still has plenty of pulling power to pull a out of gas quad thru miles of trail with a big fella on the quad,,, like somebody with the same initials as Derrick Adams
    Good swap IMO.
    john
    Dec 2007
    Quebec,Canada
    1,014
    I'm preety sure the sx and es differential is the same,same ratio.The ratio difference is in the transmission.I have many spare sx and es gearbox and the are all the same.....The main difference is the axle and hud between 85 and 86.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    1986 ATC250SX FATCAT
    Apr 2002
    s.w. michigan
    6,498
    Drive shafts are different between the 2 years (slightly different) Dominic.
    Yes, you are right, there are tranny gearing differences as well.
    But I got the proof in the pudding (so to speak).
    john
    hey, the sx has one less tooth on the ring gear[36 vs 37] than the es.
    one cylinder is not enough!!
    Oct 2007
    Minneapolis mn
    4,067
    Whats the pinion count?
    The ES diff gives you more low end grunt but less top end speed.
    The tranny gears DO CHANGE, (although it's been argued about a dozen times) but that is what it is.
    The big speed change is in the diff of the silver colored ES differential......................
    Mar 2003
    Australia
    1,919
    Awesome thanks. Anyone got an 85 sx diff for sale and willing to post to Aus?
    hey, the pinion is 9 teeth. the 85-7 trx250 uses the same design. there are a lot of them out there.
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Here ya go, post #4; http://www.3wheelerworld.com/showthr...+es+gear+chart
    The TRX diff can be swapped in too. It has alot more torque than the SX diff. With 21''s it climbs hills great but can't go fast at all. With 25''s it is perfect.
    15T3FN1 CE/FI/SI with a Class A; Some of you might know what that means.
    1986 ATC 200x, Gathering parts for a 200sx build.
    1985 ATC 250SX 25" tires, extended swingarm, snorkel and other mods for Alaska adventures.
    1985 ATC 250SX, Big plans for this one...
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Oct 2007
    Minneapolis mn
    4,067
    The ES has a 4.11:1 gear ratio.... Hahaha... Drag gears!
    Mar 2003
    Australia
    1,919
    anyone know what the sx has in terms of ratio?
