Thread: '83 200x slipping in 3rd
    Nov 2009
    Okauchee, WI
    555
    I've been trying to diagnose all the problems with my 200x before I tear it down for a rebuild. One thing that I've noticed is it seems to be slipping in third gear only. Kinda like it'll slip then catch then slip then catch. Almost like the tires are spinning, but they arent. Only does it in third. Would this be a clutch or tranny problem or what? Anyone have this happen to them? Thanks.....Matt
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Nov 2009
    Okauchee, WI
    555
    Anyone? Anything?
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Des Moines, IA
    1,303
    That's strange. I'm no expert, but it seems like if it were the clutch, it would do it in all the gears. On the other hand, something broken in the transmission should be more obvious, like grinding or lurching. It almost has to the the clutch!
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    6,817
    Yep missing teeth in the tranny . I woudnt run it to much with all that metal getting into everthing .
    Nov 2009
    Okauchee, WI
    555
    That's kinda what I was thinking. I changed the oil today and noticed some shavings. Gonna really have to tear the engine apart. Might have to look into one of the Lifans. Are they as powerful as the stock x engine? Thanks.....Matt
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Feb 2009
    michigan
    2,387
    if you go lifan they are comparable in power to stock,but i wouldnt try to build one up.leave it stock.your honda motor sounds like shift forks.maybe put some funds into the honda motor.
    1985 ATC 250R
    . Team Red Trike
