My brother-in-law's '92 Bayou 220 won't idle or run. I rebuilt the carb, making sure all passages are clean. The intake boots are crack free. The spark plug is new and gapped properly. The air filter is clean. The float bowl gets plenty of fuel. The mixture screw is backed out just over 1 turn even though it's supposed to be 1.5. Anything over what it's set at and it will run for about 2 seconds. I can get it to idle for about 10 seconds and it shuts off just like someone hit the kill switch. If you hit the throttle before the 10 seconds is up, it shuts off immediately as well. It doesn't even try to gain any RPMs. About the only thing I can think of is an electrical issue and that's not my thing.
