I have never heard of this, but would be interested in doing it to my 200S if it hops it up some. Anyone?
A xr200 cam from 81-84 will fit,same head anyway.The cam can be changed without removing the head cover.Remove round valve cover,slack the valve adjustment remove timing chain and gear and the cam will go out.Same thing to install the xr cam.And readjust the valve.The xr cam help for higher rpm,but if you want a real different,swap the carb from the xr too.I have one this swap on my 200x and there is a great difference.
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
