Results 1 to 15 of 20
Thread: O-Ring CHains...worth it?
    Des Moines, IA
    1,303
    As I slowly get all the parts to put my ATC125m back together, I'm in need of a drive chain. I'm going to have to replace the chain and sprockets. I noticed there was originally an o-ring chain on it. Are these worth the price that's charged for them? Some say the o-rings don't really keep out dirt on ATV's like they would on a street bike.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    1,736
    basically the o ring is suppose to seal in lube and keep dirt out, o ring chains dont need to be lubed and normally last longer because of it, but they put more resistance on the drive too. non orings need to be lubed alot and with all the lube dust sticks and builds up and because of that wears out faster, but if u dont mind cleaning and lubing it will last just as long and be less resistence for your 125 to turn over.
    they dont use o ring chains for racing.
    but the cheapness of the non o ring will be replaced with buying chain lube constantly.
    Oct 2006
    Wapakoneta
    815
    O-ring chains are nice, but i wouldn't run one on that small of a displacement, as Mr RPM said the resistance is higher
    1,736
    well they run o-ring chains stock. so getting a non o-ring chain might make it faster, i recently went from the original 84 o-ringed chain to a new o-ring free chain. didnt notice to much but at that point the old chain was skipping over the sprockets and this was in the snow so its hard to tell. but the O-ring chain did last 26 years so.... thats your advantage if your not into cleaning and lubing after every good dirty ride. but even if you just sprayed some lube now and then it will last 10 years since there is no suspension on our bikes
    Des Moines, IA
    1,303
    Ok, so on to the next question....how often do you guys lube your chains? I mean, really? I don't think I've ever done one. I'm not saying this is a good or recommended thing, but just a fact. Maybe something I need to start doing?
    Feb 2009
    michigan
    2,387
    everytime i ride in rain or mud i clean and lube.if i ride on a nice day i dont.
    1985 ATC 250R
    . Team Red Trike
    Oct 2007
    Minneapolis mn
    4,067
    On my BR shafty, I never oil the chain... On my rocket, every couple of days of riding....
    1,736
    back on my warrior and 400ex atleast once a week (we rode like everyday), but the 110, never did because it was o-ring and i just didnt care. my first 10 years with my trike i just beat on it and didn't appreciate it. only now am I taking care of it, but im making up for what i didnt do in the past lol.
    N.E. Ohio
    2,002
    I use a chain wax, after every ride.
    May 2008
    Northwestern Ontario, Canada
    552
    I spray the chain with chain lube once in the spring and once in the fall, takes all of 2 minutes...but I don't ride that much in dirt and the chain is still well sealed. If I was running in mud/water all day I'd probably do it more often.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Aug 2002
    691
    I think in moderate conditions they probably help and do last longer but I think alot of people see a o-ring chain as being completely maintenance free...It still needs cleaned and lubed every now and again, but maybe not as often as a regular chain. I say for those really sinking the bikes in the mud every ride it probably doesn't matter which you run haha.
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    st. louis, mo.....usa
    508
    after all that, i have a stupid question. would the chain matter on a 250r or 350x as far as resistance goes?
    I report posts...
    Apparently it tortures more than my wife...LMFAO
    http://www.3wheelerworld.com/showthr...r-phantombiker...feedback
    85 Tri Z...sold
    85 350x sold
    84 200x sold
    85 250r...sexy as he!!
    1,736
    Quote Originally Posted by phantombiker View Post
    no, you won't be able to tell a difference as far as resistance goes.
    508
    Quote Originally Posted by Mr_RPM View Post
    so, it would be a power/resistance ratio that you were referring to in earlier post? sorry for stupid questions. not familiar with the technicals of bikes.
    I report posts...
    85 Tri Z...sold
    85 350x sold
    84 200x sold
    May 2008
    552
    Boils down to how easy the chain spins around the sprocket...O-ring chains are stiffer that way, but on a bigger machine that fact is negligible!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
