Results 1 to 15 of 27
Thread: ATC200, ATC200M and ATC200S Technical Data
    Maryland
    3,077
    Article: ATC200, ATC200M and ATC200S Technical Data
    Finger Lakes Region, NY
    613
    Nice link! Thanks...
    ...the branch cannot bear fruit of itself, unless it abide in the vine...
    oregon
    does any buddy starting point on the 84 200s for carb has keihin has a screw on the side plus needle type screw in the middle going up to the carb body I don't know much about these ol 4 strokes but my kid got this 3 wheeler given to him it is in excellent shape usually starts right up but when you shut it off it wont start again unless you pull plug and clean usually wet when he pulls it out also when choke is on is throttle body flap closed or open thanks
    Aug 2010
    florida
    26
    1984 200s
    Quote Originally Posted by chrisk121 View Post
    There is a plastic choke lever on the left side of ATC. put the choke on and see if it idles up or if it dies. Sounds like it is running rich and getting wet or if it is oil then look to rings or valves.
    detroit michigan
    80
    its the first time really trying to start it after putting it back together the guy i got it from gave it a paint job then got sick so i got it cheap but had a lot of work to invest luckily a friend sent me the manual and i got it together in one day. http://www.youtube.com/watch?v=nD5NJfb1FnM
    detroit michigan
    80
    waitin on the ratchets and ratchet springs n clip that all go to the pull rope assembely.should have the money soon to get them then ill be able to test drive it. cant wait
    detroit michigan
    80
    detroit michigan
    80
    got it goin perfect the needle connected to the throttle line was put in wrong by the previous owner so it would hold it open heres its first running vid http://www.facebook.com/video/video....33488&comments love this thing
    mirthgrinder is offline At The Back Of The Pack Arm chair racerFirst time rider
    Cypress, Texas, United States
    180
    So....
    Quote Originally Posted by wheelz420 View Post
    Are you addicted Yet???
    Nov 2010
    Hoodsport Washington
    40
    yeah mine was like that but when i got it back from the shop I still had to roll start it. we fixed it though. its addicting and I love poping wheelies with the touch of the throttle.
    detroit michigan
    80
    detroit michigan
    80
    100% addicted
    hartland nb canada
    86
    can any1 give me some help.i got a biek and i think i might have 2 or 3 bikes in 1.the motor it pull and no high or low.isnt that just the atc 200.and the muffler is just over the rear end and i think thats a 200s if im right.that wood make the frame 200s..i just dont n o.and i need some1 to give me some help with clutchs.i dont no how to do them as in set them.
    detroit michigan
    80
    heres a link to all honda atc manuals it helped me alot and should set you up
    Quote Originally Posted by zackwhite View Post
    http://oscarmayer.net/atc/manuals/ injoy
    burnin rubber
    detroit michigan
    80
    keep us updated
    burnin rubber
