Getting a lot of movement on the rear brake caliper bracket causing a bad noise. I know that some movement is normal, but it is moving front to back and side to side. Thinking 2 things: Carrier is worn around where the bracket fits on it or the rear parking brake is adjusted too tight/froze up holding the brakes too tight. Any experiences with this? THanks for the help. By the way, it is an 86.
