Results 1 to 15 of 18
Thread: Cam options for ATC 90
    Wisconsin
    201
    DrATV is out of them for the next few weeks. I was wondering if their are any other suppliers for a performance cam. One guy contacted me and said he had one for $57. I feel that is a bit to high for just a 2 lobe cam.
    6,797
    My price is not bad at fifty bucks for a NOS part . Try powroll or web and you will really pay . I might have a lightly used race cam or one not in the box but NOS for a bit less .
    PA
    3,515
    Megacycle cam
    Thats what I run in all my motors, even my 110.
    WWW.HREATV.COM
    1,736
    Quote Originally Posted by SWIGIN View Post
    Megacycle cam
    there are 2 cams for the atc110, which do you run? the mild or race? for the race they say run race piston, what piston would this be?
    6,797
    Quote Originally Posted by Mr_RPM View Post
    Race pistons like these .
    Attached Thumbnails Attached Thumbnails pistons4..JPG   pistons2..JPG   pistons3..JPG   pistons..JPG
    1,736
    i just wondered if it was a specific piston made by that company to assure proper valve clearance, must be for compression reasons then. i already got a race piston so thanks for the info SWIGIN looks like im going to get one
    Wisconsin
    201
    What is the lift, duration and price?
    6,797
    Quote Originally Posted by turbowrenchhead View Post
    I have 2 NOS #98 grinds made by Web 35.00 each + shipping .
    Here is their website for the for details .
    http://www.webcamshafts.com/404.html
    Wisconsin
    201
    Would you say this cam is a good mid range to high range cam? I want to match the cam to the 56mm piston at 10.5:1 ratio.
    Would you happen to know what the stock cam lift and durations are?
    6,797
    Yes it will improve mid range and top end and if you use the 55mm big bore kit it will really wake it up . I have never seen a big bore kit for a atc90 in 56mm and the atc110 56mm is not interchangable they have different wrist pin sizes . wrist pin on a 110 is 15mm and the 90 is 14mm . You could get a atc110 crank from a 1979-80 atc110 and put it in your 90 cases and use the atc110 cylinder and it will be like adding a small stroker to your 90 set up making it 125cc .
    Wisconsin
    201
    Good to know. That is something I have not learned yet. Thanks. I can get a crank and rod off of ebay. Are they pretty much a drop-in into the case? Or will there have to be some modification to make it fit?
    I would like to get that cam from you then. Take paypal?
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    6,797
    Yes the atc110 crank is a bolt in deal but only a 1979/80 points model motor and you have to use the 110 cylinder and timing chain because the stroke is longer . I will pm you the paypal info .
    Wisconsin
    201
    Do you think it is worth doing? I do have concerns over the cylinder wall being to thin. But I like the idea of higher compression. I could go with the 54mm and have a thicker cylinder but have less compression and hp too. I was planning on replacing the chain, the valve springs, piston/rings and replace all the gaskets and seals while I'm at it. I will go through the head and port and polish what I can and lap the valves if they are in good condition.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    6,797
    Yes I believe its worth doing just shop around ebay for a deal on atc110 crank and cylinder . A 54mm piston in a atc90 will give you 104cc which is good but with the atc110 stock crank and a 55mm piston the atc110 will be a 123cc power house . or if you want to go big I have a 61.5mm stroker that will really make it BARK LOL .
    Feb 2003
    Australia
    927
    Don't forget the 90 cases will have to be bored to accept the 110 cylinder.
