Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Cam options for ATC 90
    6,811
    Quote Originally Posted by greenhuman View Post
    Don't forget the 90 cases will have to be bored to accept the 110 cylinder.
    Yes I forgot about boring the cases on the atc90 bottom end . The other option is to use the atc90 cylinder bored to 54mm and a spacer under the cylinder to compensate the length of the longer 110 stroke .
    Wisconsin
    201
    Ok just to let me get this straight. If I go with the 54mm DrATV piston at 9:1. I can use my stock cylinder. All I have to do is bore the stock one and no modifications to the case. Puts me at 104cc
    Cost:
    54mm piston $60.00.
    Bore cylinder $40.00
    If I go with the 56mm 10.5:1. I need to get a 110 cylinder, bore it. Bore the case and change the crank and rod. Also install a 110 timing chain. Puts me at 125cc? Also how thin with the cylinder wall be? I have seen opposing opinions on the 56mm piston. Some say its safe others disagree.
    Cost:
    56mm piston $30
    Crank&rod $60
    110 cylinder $50
    Boring $40
    Plus modifications to the case. Can this be done by hand with a die grinder? I am assuming that the opening has to be large enough so the rod doesn't hit it.
    I have not seen a 55mm piston anywhere.
    I want to understand all the in's and out's of these mods before I decide to start buying parts. I have the funds available but first I need to know what processes I must go through.
    Thanks for all the input, its greatly appreciated.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    6,811
    Sounds like you got it . The 56mm piston does make the cylinder pretty thin but your not making a 10,000 RPM monster so I wouldnt worry to much and the 55/54mm atc110 pistons are very hard to find . Not exactly sure how much material has to be removed from the 90 cases but I dont think its much , prob 1 to 2 mm .
