Results 1 to 3 of 3
Thread: Headlight mounts.
    B.C. Canada
    63
    Headlight mounts.
    Does anybody have a picture of the stock headlight mount for a 82 ATC200? when i got mine it had arms added to mount the light up higher. Took the arms off and the light housing hits the neck before it lines up with the holes know. Ive tried putting the light were the lower bolts go thru the alum arms. i
    Baltimore, MD
    6,088
    Well, you have the stock mount on there. But the problem is as part of the front rack kit when they came from honda, they had an assembly that raised the headlight about the rack area. You don't seem to have that part of the rack kit. Therefore the stock mounting points that you have won't work right. You may have to fab something up that looks a tad better than what you have now. Sorry to be the bearer of bad news about that.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    B.C. Canada
    63
    Alright thanks. The racks are off it now. All post pics of what i end up doing.
