Thread: ATC70X suspension built!
    Dec 2007
    Quebec,Canada
    1,014
    I'm starting the built of a ATC70X,from a sl70 frame,I'm planing to built a reverse kick system
    The swingarm is built with some parts of a 200x swingarm.The bearing cage been shortened to fit the atc90 or 110 axle,not sure.The disc holder is from the 200x,the disc is from a scooter,the bolt pattern is the same.....I built excentric adjuster on the swingarm pivot,to adjust the chain.The shock is from a 83 cr80.The front....triple clamp is from a suzuki rv90,shock are from a honda ST90.The rv90 clamp need to be modified to fit the bearing on the sl70 frame,the tire fit perfect in the fork.
    I cut the frame and change the fork angle,the sl70 frame give 8 more degree,now I have 2 more degree compared to the stock atc70,this will help for clearance between tire and motor since I have suspension.Stock the atc70 have 35inch between the center of front and rear wheel,now I have 36 inch.....the stock sl70 frame give 39 inch.
    I will install a 4 speed manual clutch motor,a custom built motor from many honda parts....
    Can wait to ride it!!!!
    Attached Thumbnails Attached Thumbnails trie 015..jpg   trie 014..jpg   trie 013..jpg   trie 017..jpg   trie 016..jpg   trie 012..jpg
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Beaver Falls, PA
    2,666
    looking real good... check out the wee swing arm!
    Mar 2008
    EastGreenbush, newyork
    3,494
    nice build man, thing oughta bea blast when its done!!
    Monroe MI
    5,787
    OHIO
    2,857
    I am very interested in reverse kicker as I have thought of several ways to do it just never built it. Please post pics of kicker.....would be very useful!! Nice build going there........
