Originally Posted by
dblungshot
1985 250es
I replaced the carb with a very clean used carb and installed all new jets and seals (carb kit). My trike will start without a choke pretty quickly but not on the first attempt (no biggy). It seems after the trike is warmed up the idle increases in RPM's randomly. It takes a few throttle rev's to bring it down to normal idle, but some times I can't get it to come down (which makes shifting a biotch). Any ideas what jet or what the problem is??? I've read and reviewed the carb 101 and can't figure it out. I live at sea level and the carb location I replaced it was used from the east coast (unknown elevation). The jets were all replaced though and I thought were replaced correctly. Is this a fuel mixture screw that needs adjustment?
Also, this may lead to the answer or not? After my trike is warmed up or has run for a few minutes it begins to die. If I open the gas cap (with a suction), the fuel begins to flow into the carb, replacing the engine die with a normal idle. I'm assuming my gas cap is stuck in the "off" position stopping the fuel flow. Is this assumption without a doubt correct or may this be linked to my carb???
Any help will be appreciated. I've fixed everything else on this 85' and want it to be running like a dream instead of not. Any input will be awesome!!
Gig Harbor, WA.
1985 250es
1972 Rokon Trailbreaker
