Results 1 to 12 of 12
Thread: Fowling spark plug
    Gatineau Quebec
    16
    Fowling spark plug
    Hello!
    I'm new hear, i recently bought an 84 honda 200cc 3wheeler. it runs great, starts great and i'm very happy with it, but it keeps burning through spark plugs. like 2 plugs per tank of gas. starting to get expensive,lol. any one know what might be wrong?
    thanx in advance,
    Mat
    Feb 2006
    north of buffalo
    557
    Welcome to 3WW. fowling like a bird? oh you mean fouling, use the search engine on the main page, this topic has been talked about a lot.
    Runners:
    84 200s
    05 rancher
    12 rancher
    Gorrie Ontario Canada
    10
    I had the same problem on my 84 Trx 200 and it uses the same carb as yours,went to honda and got a rebiuld kit for the carb and no more problems.When you get the kit it will only have a jet needle and needle jet.When you replace the needle jet compare the new one to the old one and you will see how badly the old one is worn,not much but it will make a huge difference in the way your trike starts and runs and no more fouled plugs.
    Hope this helps
    1,736
    your running to rich if your going threw plugs, to much gas. finding the reason why is the tricky part, maybe its what big danno said
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    had the same problem but mine was even worse, i just pulled out the carb to clean it very well
    and it was completly solve never had any fouling anymore and the trike ran even better
    Gatineau Quebec
    16
    Thanx for the replies, bringing it in to a friends for a nice tune up and carb rebuild. hey i'm new to bikes, but i've been running the whole time with the gas valve thingy on ''reserve'' the whole time, could that have anything to do with it?
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    reserve is there for when you run out of gas in the "on" postion. does it smoke/ burn oil?
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    indiana
    Buy a adjustble float, set height and this will allow you to lean it out a lean it out
    Gatineau Quebec
    16
    no smoking or oil burning,,,, must just be the jets/dirty carb thats causing the fouling. i figure out the reserve part, just wasn't sure if maybey that would have caused it. kind of a cool option, now that i know about it..lol
    Canada,barrie,Ontairo
    229
    my 1982 xr 80 use to blow plugs all the time. all i did was tune the carb air an fuel mixture and that fixed it .
    is the thing hard to start?
    Aug 2009
    Perth , western australia
    24
    I had the same problem with my 200e, Jet was too big so i couldent ajust the mixture. Mechanic also said that if the oil in the case is old itll have toomany metal particals in it, this will make it stick to the plug. so I changed my oil . much better.
    Gatineau Quebec
    16
    good hints thanx guys, no she starts well when it s a new plug.
