Results 1 to 6 of 6
Thread: 200x Clutch adjustment
    mike1979 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    Michigan
    406
    I want to try to udjust the clutch on my 85 200x, it slips a little whe I goose it but is otherwise fine.
    Is this easy to do or should I take it to a professional?
    I adjusted the clutch on my 82 atc200 but this is obviously different
    Any help/info would be greatlyy appreciated!
    6,810
    the only adjustment their is on a 200x is in the cable . You should have just a little slack in the clutch cable . sound like you need new plates .
    Feb 2009
    michigan
    2,387
    your cable properly tight???[adjudsted].you may need new clutch disks.
    1985 ATC 250R
    . Team Red Trike
    Sep 2009
    Michigan
    406
    Is replacing the discs complicated?
    Ontario Canada
    5
    how did u adjust the 200?
    Crest California
    3,014
    Are you sure you adjusted it properly? There should be just a little bit of slack on the clutch handle (just very slight, like 1/8") which will keep everything as tight as possible, but release the clutch completely.
    LED obsessed
    2015 Yamaha FJ-09
