Results 1 to 3 of 3
Thread: 86 Tecate carb
    tmecars is offline At The Back Of The Pack Arm chair racerFirst time rider
    86 Tecate carb
    Does anyone have a diagram showing the complete carb assembly for an 86 T3? Im having a hard time getting mine started after dumping it in a few feet of water. Like the tech tip of the day posted earlier, I think I should completely disassemble it and clean the jets really good. Im not the best guy with a set of tools so I really need that diagram before I start tearing stuff apart!
    thanks
    T
    Jul 2003
    936
    the kawasaki webpage has info like that....breakdowns of all the bikes, i know they have tecate diagrams because i recently printed out some 85 tecate stuff from there....
    www.buykawasaki.com
    i got this from there
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    Jun 2002
    Mississippi
    2,552
    i read the post you made on the other site. i hate to say this but you may have big problems. first you need to make sure you are getting spark at the plug. next you need to run a compression test. while getting water in a carb will stop your trike from running it should be fine once you drain the gas and water from it. if dirt did get into the carb then it also got into your engine. now here is the bad news. water does not compres like the gas and air vapor that is normally there. the water will be just like a rock when the piston gets to the top of the cylinder. the force of the spining crank will shatter pistons and break/bend rods. it can even bend a crankshaft. i hope this is not your case but it aint looking good.
    dont you live in texas?
    later
    chris
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
