Results 1 to 9 of 9
Thread: 84 200X oil pump screws. Any trick to removing them?
    North Alabama
    Hey I'm new to 3wheelerworld. I am in the process of repairing/restoring a 84' 200x I picked up this winter. I have got the frame and suspension cleaned painted and repaired like I want it and I am ready to go through the engine now. I have rebuilt several 4 stroke and 2 stroke atv and dirt bike engines, but none this old. Because this thing is so old, and because the cam and head looked like crap I want to inspect the oil pump for wear and replace the gaskets. I cannot get the 2 phillips head screws that hold the pump to the engine case out to save my life though. I broke the tip clean off a Snap-On #3 phillips trying. The screws are not stripped (yet). Is there some sort of trick to getting these things off? I can turn the oil pump rotor by hand and and hear it sucking and gurgling on what oil is still left in the oil passages, not to mention the head was full of oil when I removed it and leaked like a sieve so I think it may be ok but I want to know for sure. Any suggestions? Should these things be this tight, I mean seriously?
    Sep 2007
    100mi west of Chicago
    3,582
    They are crazy tight. I ended up having to use my Dremel with a cut off wheel to turn them into a straight slot after I stripped the Phillips. Then I pounded a straight slot bit into the new slot. Then I used a ratchet to turn that lol.
    Rob
    Dec 2009
    Chicagoland
    318
    I found that tearing my old Yamaha apart. I had to keep a pair of small needle nosed visegrips around for most of the screws! They don't work in tight spots, but they work!
    Vernon Wisconsin
    188
    Did you try using a hand impact driver (one you hit with a ??) If there is room that might do it. Sears probably has it...
    http://www.thetoolwarehouse.net/p-3064-lisle-29200.aspx
    '79 Honda Odyssey
    '81 Kawasaki KLT 200 (highlighter)
    '85 Yamaha Tri-Z
    '82 Suzuki GS450L
    '05 Suzuki Eiger 400
    North Alabama
    Sounds like it's not unusual for them to be really tight. I should have a replacement screwdriver soon, I don't want to stick a cheapo in it and round the threads out. I thought I might try heating the case up a little with a propane torch in the area of the screws.
    PA
    3,515
    I had a 200x back when they were new and those screws were PITA tight back then. The only easy way to get them out is use a impact screw driver like was said abouve.
    WWW.HREATV.COM
    Feb 2008
    Berlin,CT
    61
    Quote Originally Posted by WisconsinJohn View Post
    that would be the best way thats what i used
    85 200x-redone frame up,extened rear axel,clarke plastic gas tank,dg exaust system,ceet atc seat cover,and much more....
    86 klt 110 - stock in need of top end rebuild
    Maine
    73
    i agree...i just made a post on another thread about using an impact driver on stuck bolts....sure beats stripping out phillips heads!!
    TRIKES....BADDD ASSS BIKES!!
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    OHIO
    2,857
    yes sir.....impact driver th only way.........or the best way I should say.
