Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: odd and old time fixes and tricks. Lets hear 'em
    Pacific NW
    4,255
    Gas tanks rust so keep them full.
    -empty and dry them for storage and drop in a little piece of dry ice (frozen carbon dioxide) to drive out the oxygen.
    or since propane is heavier than air, top off the tank with propane to displace the oxygen?
    sounds dangerous but then again so are gasoline fumes.
    - freeze press in carb jets with that freezing wart remover to shrink them for easy removal.
    True poetic justice for those problem gremlins.
    Southern MN
    1,875
    This thread could get interesting. One I can think of off the top of my head is seating a tire bead on the rim. If you are having problems, and the air and compressor cant get it to go, all you need is a can of starting fluid and a match. Spray a little inside the tire, then around the bead/outer rim lip. Make a trail going off the tire onto the ground, stand back, and drop a match on it. BOOM! Bead is set on the rim. It is really neat to watch, and also freak people out. Be careful!!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Aug 2004
    Ab Canada
    4,368
    have heard of a Soup can used on old Tundra's (sleds) For a piston with blown skirts to get ya home....Works...Just destroys everything else...Better than being stuck in the middle of nowhere in -35...
    1985 Tri-Z-
    Sep 2007
    oregon
    2,292
    on my first 200x my kick start return spring broke so I had a rope tied to the frame to loop it over the kick start to hold it up. Another time I got tired of my cobra exhaust being so loud I shoved a bmx seat post in it, it worked.
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    Quote Originally Posted by MTS View Post
    only in canada,lol.
    Masshole
    2,191
    When I was young I had a bunch of POS wheelers. Always seemed to find the ones with leaky fuel ttanks. If the leaks are small like pinhole sized, I used to keep a crayon in my pocket. Smear it over the pinholes and it would stop the leaks for a lil while.
    Beaver Falls, PA
    2,666
    Quote Originally Posted by Escanabajosh View Post
    only in canada,lol.
    Red Green is from Canada
    Duct tape fixes anything!
    Aug 2009
    Newfoundland, Canada
    915
    I don't get this whole Canada stereotype. Its not like canadians can only fix things like a redneck
    PA
    3,515
    If your down to your last spark plug and your bike wont start, just take it out and try to clean it some. Then dip the end in gas and light it on fire or hold a little torch on it till it's hot. Then put it back in before it cools too much and it should fire.
    WWW.HREATV.COM
    PA
    3,515
    Quote Originally Posted by MudBug View Post
    I dont get the anti USA vibe I get from some of you guys on here.....but I deal with it.
    I sugest we all man up and get thicker skin, this ''my feelings just got hurt'' stuff is WAY out of hand.
    WWW.HREATV.COM
    1,641
    Take your dirty foulded plugs and soak them in vinegar overnight.You will get some more use out of them.
    Oct 2007
    Minneapolis mn
    4,067
    Lemon scented Pledge when you are detailing... Works awesome as a tire shine, not greasy, satin finish and smells great! (not really a trike trick, but I now want to go wash the BR and shine the ITP's...)
    Daltons200x's Avatar
    Daltons200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Levittown, PA
    183
    Quote Originally Posted by Thorpe View Post
    lol my dad tought me about pledge too! he uses it on his trucks. lemon pledge brings back faded paint like you wouldnt beleive. as long as your consistent with it, his trucks look waxed all summer long
    Rides:
    1983 suzuki alt50
    1985 honda 200x
    Feb 2003
    Australia
    927
    Picture this. On holidays in 1976 with my ATC90. The carbie kept flooding so I pulled it apart and there is all sorts of stuff in the float bowl. Cleaned it out and half an hour later same thing. I went to the local bike shop nd this mechanic said they didn't have ay inline filters but he sold me some clear fuel hose and he said to make two small loops with the hose before it gets to the carbie. Any crap in the fuel will sit in the bottom of the loops. It worked a treat for months.
    Pacific NW
    4,255
    fuelline
    Quote Originally Posted by greenhuman View Post
    Thats one my favorite tricks and I use it on everything especially with that new see thru blue or yellow and now that pastel blue stuff.
    Doesn't need clamps so I loop it down, sediment lays in the bottom of the loop , pull it off the carb and let it drain itself and slip it back on. It can be a foot too long because the fuel will find its way back up.
    A 5 second procedure and filters last forever/
    Catches water too
