NEED HELP ASAP.. 200x timing chain
I am right in the middle of getting the top end on. When I went to put the gear on the cam.. The timing chain is way too tight still. The tensioner is pushed all the way. Need suggestions on which way I should go next.
Are you sure you don't have it bunched up on the crank sprocket?
Rob
I pulled the cam out.. Engine and chain both spin smoothly.
I pulled everything apart.. One of the tensioners was messed up a little. I replaced it and put it back together.
//ArrowChat Integreation Code
