Thread: NEW Cam doesn't have a timing mark
    Jul 2008
    MD
    911
    I just got done putting the engine back together but it will not start.
    So I am wondering if I have my cam in 180 deg out.
    The new cam doesn't have a timing mark to line up with the gear.
    At TDC which way should the lobes face?
    Lancaster, PA
    1,738
    lobes should be down so there is a gap between the rockers and valves, Why don't you just call me when you have theses questions? LOL
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Jul 2008
    MD
    911
    That's the way I put it.. I just took it apart again to check.. I was getting spark on every 2 or 3 kicks. Still will not start
    Blue answered it perfectly.......
    TDC, use a straw in the plug hole if you have to, then both lobes are away from the rocker arms like a perfect "A" on center..........
    Jul 2008
    MD
    911
    That's the way I did it.. I took it apart to make sure.. and put it back the same way. Still wouldn't start.
    I pulled the pulse generator off of my father's 200s.. It starts on one kick.
    Thanks for you help.
