Thread: tri-z bottom end seal question
    Mar 2008
    p.g. B.C. canada
    48
    can the bottom end seals be changed without splitting the case on tri-z,reading through the manual it seems it might be possible.
    Bryan Raffa can answer this........
    If there is no "shoulder" in the way, then most seals can be changed. But if the seal is leaking, the main bearings may be worn and have play in them......
    yep the seals are.. replaceable with out splitting. But like crasher said ,,,, chances are the bearings are smoked also..
    Mar 2008
    p.g. B.C. canada
    48
    thanks for the info
