Thread: oil leak
    mike1979 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    Michigan
    406
    oil leak
    Is it possible to be leaking oil from the spot where the kicker goes into the cover on an 85 200x? Is this a hard fix?
    Jun 2009
    Leander TX
    2,217
    Yes it's possible. I don't know how hard it is because I have not done it myself. If it's like shifter shafts and clutch shafts, it could be as simple as taking the kicker off the shaft, pulling the seal out, putting the new seal in, and bolting the kicker back on.
    Nov 2009
    Okauchee, WI
    555
    I looked at my manual and it says ther is an oil seal on the cover for the kick starter that the shaft goes through. Looks like it could leak.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Sep 2009
    Michigan
    406
    I popped the kicker off, I had a loose bolt on the smaller cover, problem solved I hope
