Thread: 200s pulse generator help
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    when i tighten up my pulse generator base my engine gets real hard to turn . when i loosen it its frees up and engine runs fine.
    is there some kind of thick gasket or spacer that goes on the base to the head or only the O ring ?
    it runs fine but it leaks some oil when its not tight .
    84 200s almost done
    84 atc 70 project
    6,810
    sounds like the cam bearing wasnt set right . did you just rebuild the head and have it apart ? are you using a gasket at the advancer cover ?
    Feb 2009
    greentown PA
    389
    no it wasnt rebuilt yet. and it happens on 2 diffrent heads. there is only an O ring on the base right now ? gasket missing i guess ?
    84 200s almost done
    84 atc 70 project
    6,810
    Quote Originally Posted by PAPA250r View Post
    You Need the gasket
